Go to Post I fear not the drive team who has practiced 10,000 defenses once, but I fear the drive team who has practiced one defense 10,000 times. -Bruce Lee - bEdhEd [more]
Unread 16-02-2013, 00:23
chriz4gx chriz4gx is offline
AKA: Christopher Villar
FRC #2871 (Beantown Botz)
Rookie Year: 2012
chriz4gx is an unknown quantity at this point
Connecting to Radio Taking A Long Time
So every time we power on the robot, the Driver Station always takes a long time to connect. For some reason it doesn't automatically connect to the Robot Radio. I have to Ctrl+Alt+Delete and switch the user to the developer and then in the wireless bar on the lower right corner gets connected to the Robot Radio. The classmate is set up that it that it automatically connects to the Robot Radio. I don't know why its taking so much time to connect. Shouldn't the Driver Station connect automatically to the Robot Radio straight from the "Driver Station" User on the classmate? Are there ways to fix this problem? Thxs
Unread 16-02-2013, 01:45
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Connecting to Radio Taking A Long Time
Is it connecting to some other network first? Try telling it to forget all other networks it might have joined before. If you do need to use another network at times, configure that other connection's settings so that it'll switch to a higher-priority network when available.
Unread 16-02-2013, 11:17
Rookie Year: 2012
We have made the classmate forget all the other networks that were saved except our robot radio and our robot radio from last year, but still it takes a long time to connect. Any other suggestions?
