Go to Post Pushing match, what pushing match? If they can't catch you they can't push you around. - IndySam [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 16-02-2013, 07:00
bardd's Avatar
bardd bardd is offline
That loud guy
AKA: Bar Danino
FRC #2212 (The Spikes)
Rookie Year: 2011
bardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant future
CAN being wierd
We're using CAN for the first time. We have two jaguars chained and connected to the cRIO's serial connection.
When we try to activate both jaguars simultaneously, one of three things happen:
  1. Both jags work correctly,
  2. Only one jag works (always the same one), the other's signal light shows it gets an "enabled" signal but no "move" signal,
  3. None of the jags work.
One thing we noticed is when you change the voltage you want the jags to send as output drastically over a short period of time, both jags don't work.
We have no idea why that happens... Help would be very much appreciated.
Team FRC#2212 The Spikes, 2011-...
Builld leader 2013
Drive coach 2012-2013
Mentor 2015-...
