Go to Post You all have made me think about this in a new way - which I appreciate. - aaeamdar [more]
Unread 16-02-2013, 09:20
jalmos jalmos is offline
FRC #4166
jalmos is an unknown quantity at this point
Maxbotix range ultrasonic range sensor problems??
We are trying to use two Maxbotix range sensors with little luck. We have been through the "start-up" guide and we think we have them programed correctly in Labvie, and wired correctly, but our question is where to do they get power from?
We see that they are 5v and we are guessing that power comes from the CRio somewhere but we are not sure where their power comes from either to the sensor or from the CRio. If it is indeed the CRio where do we run the power lines from the PDB?
Also we have wired in PWM cables to these sensors, but would they get power from these cables? not sure...
Also is there anything on the drivers station we need to do or activate in order to make these work.
Thanks so much for being there to help out a rookie team like ourselves.
Thanks
jalmos
Unread 16-02-2013, 10:46
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Maxbotix range ultrasonic range sensor problems??
Originally Posted by jalmos View Post
and wired correctly
If they are wired correctly, they have power. If they do not have power, they are not wired correctly. Which is it?
So let's say you have a thing on your robot that needs 5 volts. Think hard: Where can you get THAT from? If you find a spot, try using it. (Hint: If it is at a WAGO connector, keep looking)
Yes, of course there is. It's not an automatic configuration for some random sensor. OK, not the drivers station per se, but the cRio.
Please try searching ChiefDelphi, using the word "Maxbotix" for a wealth of useful information. Maybe even try the Maxbotix web site?
Help yourself by helping yourself.
Unread 16-02-2013, 11:02
FRC #4166
Does this sensor get power from the PWM cables or is there an additional power line that needs to be run from the PDB to the CRio?
Thanks
jalmos
Unread 16-02-2013, 22:14
DonRotolo's Avatar
Back to humble
FRC #0832
The 5 volts from the digital I/O pins would be sufficient.
Unread 16-02-2013, 22:21
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Thanks
jalmos
The center pin of the Analog Breakout provides +5 volts, so, assuming you have it wired correctly, it has all the power it needs.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
