Go to Post FIRST is more than FRC. - gblake [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 24-06-2002, 00:06
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
archiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond repute
Notes on building the Square Rack
Posted by Joe Johnson.   [PICTURE: SAME | NEW | HELP]
Engineer on team #47, Chief Delphi, from Pontiac Central High School and Delphi Automotive Systems.
Posted on 10/14/2000 3:24 PM MST
I just finished building another square rack on my deck, using only what I know from the rules (I did not build our evaluation rack).
I have some pointers.
Cut a single leg and cut it long (say 23 inches) then put two elbows on each end and measure the inside dimension that you get. I cut two of them 22 inches only to discover that I needed another 3/4 of an inch between the opposing two legs. I suppose that the elbows I used were made by a different source than the ones that Mike Martus used to make our initial sample.
Uses some thought before you glue. I propose making up 2 sub-assemblies of consisting of 2 elbows and a leg. When you glue the second elbow to the leg, dry-fit the two unused legs into the elbows and use them to help you make sure the elbows are 'in plane' with eachother. After you have these two sub-assemblies together, then glue the last two legs to one of them. Finally, glue this C to the other sub-assembly.
Pictures to follow soon.
Good luck.
Joe J.
This message was archived from an earlier forum system. Some information may have been left out. Start new discussion in the current forums, and refer back to these threads when necessary.
#0047 (ChiefDelphi)
Re: Notes on building the Square Rack
Posted by Michael Martus.   [PICTURE: SAME | NEW | HELP]
Coach on team #47, Chief Delphi, from Pontiac Central H.S. and Delphi Automotives Systems.
Posted on 10/14/2000 6:03 PM MST
In Reply to: Notes on building the Square Rack posted by Joe Johnson on 10/14/2000 3:24 PM MST:
All elbows are not created equal... I would have thought that there was an indusrty standard. But that was not true even at the same store, as I made two trips to get like items.
Maintain the inside distance between flats and you are all set.
My elbows used lengths that were 22.5 inches long.
[IMG] code is Off
Square Rack Sketch archiver 2000 1 24-06-2002 00:09
Application Notes V1_0 archiver 2000 0 24-06-2002 00:08
