Re: Using VEX Ultrasonic Sensor
There used to be a set of (horribly written) vis in WPIlib to support an ultrasonic encoder with two digital ping/response lines. I believe they still exist, but I'm not sure.
It used the DIO Pulse feature and DIO Interrupt features to generate and listen to a pulse. Unfortunately, it was written to Wait On Interrupt, causing the thread that called the ultrasonic sensor to hang until either a pulse was returned, or the timeout (60ms) was reached.
Unfortunately, the majority of the library is written synchronously with blocking calls like this, which is IMHO really really bad embedded code design.
The FPGA has a lot of rarely or never used features which I have never seen used, including these DIO pulse and interrupt features, and a lot of DMA capabilities.
Kettering Motorsports
