Go to Post Oh, for the love of cod, can't you see that Dave is messing with us just for the halibut? When the actual clue comes out, I'm sure we'll all be singing a different tuna. - Pat Fairbank [more]
Unread 16-02-2013, 11:56
Freeloder123's Avatar
Freeloder123 Freeloder123 is offline
AKA: Daniel Lopez
FRC #4091 (Team Drift)
Rookie Year: 2012
Freeloder123 is an unknown quantity at this point
Exclamation problem having the camera working
we have been having problem coding the camera, this is our first year trying the camera and we've decided to use the reflective tape and we've encountered our problem in receiving the image but to be able to access the image we need to click on the actual image feed
thanks
Daniel Lopez
Unread 16-02-2013, 16:05
bvisness's Avatar
bvisness bvisness is offline
Programming Mentor, Former Driver
FRC #2175 (The Fighting Calculators)
Rookie Year: 2010
bvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of light
Re: problem having the camera working
What do you mean by "click on the actual image feed"? If you can't see your camera image on the dashboard then you probably have not configured your camera correctly. The Axis Camera Setup Utility is provided for that purpose.
Unread 17-02-2013, 01:32
josneville's Avatar
josneville josneville is offline
The Chosen One
FRC #0540 (Talon 540)
Rookie Year: 2010
josneville is on a distinguished road
Under LabView Examples form last year, there was a vi by the name of rectangle tracking.vi. If you can find that vi, use the code from there to help track your image.
-Success is the Key to Life. I have no life. Hmmm......
Unread 17-02-2013, 08:21
You can also choose to open the 2013 example which has already been updated to the ratios of the new rectangles and has code about the center versus outer targets.
Greg McKaskle
