Go to Post Many software problems can be solved by plugging wires in. - Eric Finn [more]
Unread 16-02-2013, 12:41
Mubtasim Mubtasim is offline
FRC #4797
Mubtasim is an unknown quantity at this point
Exclamation Robot stops working and "output isn't updated often" errror
Rookie team programmer (in java) with no experience. The following program suppose to:
in Auto-
Start m_window motor
wait 3 seconds
Start m_shooter motor
(and do the same again when auto init)
in Teleop-
When left trigger > start m_window motor
when right trigger > start m_shooter motor
use the default code drive commands when asked.
We are using the built in default program and added the additional codes highlighted in bold.
The Program does exactly what it suppose to but shows the following error : RobotDrive: Output isn't updated often enough (not a quote). The code stops running in different interval ( when stops, every other function stops as well- it takes no input without any error massage). Sometimes re-uploading the code helps. Also the autonomous codes starts both motor at the same time when initiated from the driver-station program when running more than once.
Code:
package edu.wpi.first.wpilibj.defaultCode;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Solenoid;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.Victor;
import edu.wpi.first.wpilibj.Watchdog;
public class DefaultRobot extends IterativeRobot {
	// Declare variable for the robot drive system
	RobotDrive m_robotDrive;		// robot will use PWM 9,10 for drive motors
        RobotDrive m_window;                    // PWM 6
        RobotDrive m_shooter;                   // PWM 5
	int m_dsPacketsReceivedInCurrentSecond;	// keep track of the ds packets received in the current second
	// Declare variables for the two joysticks being used
	Joystick m_rightStick;			// joystick 1 (arcade stick or right tank stick)
	Joystick m_leftStick;			// joystick 2 (tank left stick)
	static final int NUM_JOYSTICK_BUTTONS = 16;
	boolean[] m_rightStickButtonState = new boolean[(NUM_JOYSTICK_BUTTONS+1)];
	boolean[] m_leftStickButtonState = new boolean[(NUM_JOYSTICK_BUTTONS+1)];
	// Declare variables for each of the eight solenoid outputs
	static final int NUM_SOLENOIDS = 8;
	Solenoid[] m_solenoids = new Solenoid[NUM_SOLENOIDS];
	// drive mode selection
	static final int UNINITIALIZED_DRIVE = 0;
	static final int ARCADE_DRIVE = 1;
	static final int TANK_DRIVE = 2;
	int m_driveMode;
	// Local variables to count the number of periodic loops performed
	int m_autoPeriodicLoops;
	int m_disabledPeriodicLoops;
	int m_telePeriodicLoops;
     * Constructor for this "BuiltinDefaultCode" Class.
     * The constructor creates all of the objects used for the different inputs and outputs of
     * the robot.  Essentially, the constructor defines the input/output mapping for the robot,
     * providing named objects for each of the robot interfaces.
    public DefaultRobot() {
        System.out.println("BuiltinDefaultCode Constructor Started\n");
		m_robotDrive = new RobotDrive(9,10);
                m_window = new RobotDrive(6,7);
                m_shooter = new RobotDrive(5,3);
		m_dsPacketsReceivedInCurrentSecond = 0;
		// Define joysticks being used at USB port #1 and USB port #2 on the Drivers Station
		m_rightStick = new Joystick(1);
		m_leftStick = new Joystick(2);
		// Iterate over all the buttons on each joystick, setting state to false for each
		int buttonNum = 1;						// start counting buttons at button 1
		for (buttonNum = 1; buttonNum <= NUM_JOYSTICK_BUTTONS; buttonNum++) {
			m_rightStickButtonState[buttonNum] = false;
			m_leftStickButtonState[buttonNum] = false;
		// Iterate over all the solenoids on the robot, constructing each in turn
		int solenoidNum = 1;						// start counting solenoids at solenoid 1
		for (solenoidNum = 0; solenoidNum < NUM_SOLENOIDS; solenoidNum++) {
			m_solenoids[solenoidNum] = new Solenoid(solenoidNum + 1);
		// Set drive mode to uninitialized
		m_driveMode = UNINITIALIZED_DRIVE;
		// Initialize counters to record the number of loops completed in autonomous and teleop modes
		m_autoPeriodicLoops = 0;
		m_disabledPeriodicLoops = 0;
		m_telePeriodicLoops = 0;
		System.out.println("BuiltinDefaultCode Constructor Completed\n");
	/********************************** Init Routines *************************************/
	public void robotInit() {
		// Actions which would be performed once (and only once) upon initialization of the
		// robot would be put here.
		System.out.println("RobotInit() completed.\n");
	public void disabledInit() {
		m_disabledPeriodicLoops = 0;			// Reset the loop counter for disabled mode
		ClearSolenoidLEDsKITT();
        startSec = (int)(Timer.getUsClock() / 1000000.0);
		printSec = startSec + 1;
		m_autoPeriodicLoops = 0;				// Reset the loop counter for autonomous mode
	public void teleopInit() {
		m_telePeriodicLoops = 0;				// Reset the loop counter for teleop mode
		m_dsPacketsReceivedInCurrentSecond = 0;	// Reset the number of dsPackets in current second
		m_driveMode = UNINITIALIZED_DRIVE;		// Set drive mode to uninitialized
	/********************************** Periodic Routines *************************************/
	static int printSec;
	static int startSec;
	public void disabledPeriodic()  {
		// feed the user watchdog at every period when disabled
		Watchdog.getInstance().feed();
		// increment the number of disabled periodic loops completed
		m_disabledPeriodicLoops++;
		// while disabled, printout the duration of current disabled mode in seconds
		if ((Timer.getUsClock() / 1000000.0) > printSec) {
			System.out.println("Disabled seconds: " + (printSec - startSec));
			printSec++;
		// feed the user watchdog at every period when in autonomous
		m_autoPeriodicLoops++;
		// generate KITT-style LED display on the solenoids
		SolenoidLEDsKITT( m_autoPeriodicLoops );
        if(true){m_window.drive(0.7, 0.0);}
        m_shooter.setSafetyEnabled(false);
                m_window.setSafetyEnabled(false);
                int m = 1;
                if(m == 1){
                Timer.delay(2);
                m_shooter.drive(0.25, 0.0);
        // increment the number of teleop periodic loops completed
        m_telePeriodicLoops++;
         * Code placed in here will be called only when a new packet of information
         * has been received by the Driver Station.  Any code which needs new information
         * from the DS should go in here
        m_dsPacketsReceivedInCurrentSecond++;					// increment DS packets received
        // put Driver Station-dependent code here
        // Demonstrate the use of the Joystick buttons
        Solenoid[] firstGroup = new Solenoid[4];
        Solenoid[] secondGroup = new Solenoid[4];
        for (int i = 0; i < 4; i++) {
            firstGroup[i] = m_solenoids[i];
            secondGroup[i] = m_solenoids[i + 4];
        DemonstrateJoystickButtons(m_rightStick, m_rightStickButtonState, "Right Stick", firstGroup);
        DemonstrateJoystickButtons(m_leftStick, m_leftStickButtonState, "Left Stick ", secondGroup);
        m_shooter.setSafetyEnabled(true);
        m_window.setSafetyEnabled(true);
                   if (m_rightStick.getTrigger()){m_window.drive(0.7, 0.0);}
                   if (m_rightStick.getTrigger()){ m_shooter.drive(0.25, 0.0);}
        // determine if tank or arcade mode, based upon position of "Z" wheel on kit joystick
        if (m_rightStick.getZ() <= 0) {    // Logitech Attack3 has z-polarity reversed; up is negative
            // use arcade drive
            m_robotDrive.arcadeDrive(m_rightStick, false);			// drive with arcade style (use right stick)
            if (m_driveMode != ARCADE_DRIVE) {
                // if newly entered arcade drive, print out a message
                System.out.println("Arcade Drive\n");
                m_driveMode = ARCADE_DRIVE;
        } else {
            // use tank drive
            m_robotDrive.tankDrive(m_leftStick, m_rightStick);	// drive with tank style
            if (m_driveMode != TANK_DRIVE) {
                // if newly entered tank drive, print out a message
                System.out.println("Tank Drive\n");
                m_driveMode = TANK_DRIVE;
	 * Clear KITT-style LED display on the solenoids
	 * Clear the solenoid LEDs used for a KITT-style LED display.
	public void ClearSolenoidLEDsKITT() {
		// Iterate over all the solenoids on the robot, clearing each in turn
			m_solenoids[solenoidNum].set(false);
	 * Generate KITT-style LED display on the solenoids
	 * This method expects to be called during each periodic loop, with the argument being the
	 * loop number for the current loop.
	 * The goal here is to generate a KITT-style LED display.  (See http://en.wikipedia.org/wiki/KITT )
	 * However, since the solenoid module has two scan bars, we can have ours go in opposite directions!
	 * The scan bar is written to have a period of one second with six different positions.
	public void SolenoidLEDsKITT(int numloops) {
		final int NUM_KITT_POSITIONS = 6;
		int numloop_within_second = numloops % GetLoopsPerSec();
        // note that the array index values below are zero-based, but solonoid numbers are one based.
		if (numloop_within_second == 0) {
			// position 1; solenoids 1 and 8 on
            m_solenoids[0].set(true);
            m_solenoids[7].set(true);
            m_solenoids[1].set(false);
            m_solenoids[6].set(false);
		} else if (numloop_within_second == (GetLoopsPerSec() / NUM_KITT_POSITIONS)) {
			// position 2; solenoids 2 and 7 on
            m_solenoids[1].set(true);
            m_solenoids[6].set(true);
            m_solenoids[0].set(false);
            m_solenoids[7].set(false);
		} else if (numloop_within_second == (GetLoopsPerSec() * 2 / NUM_KITT_POSITIONS)) {
			// position 3; solenoids 3 and 6 on
            m_solenoids[2].set(true);
            m_solenoids[5].set(true);
		} else if (numloop_within_second == (GetLoopsPerSec() * 3 / NUM_KITT_POSITIONS)) {
			// position 4; solenoids 4 and 5 on
            m_solenoids[3].set(true);
            m_solenoids[4].set(true);
            m_solenoids[2].set(false);
            m_solenoids[5].set(false);
		} else if (numloop_within_second == (GetLoopsPerSec() * 4 / NUM_KITT_POSITIONS)) {
			// position 5; solenoids 3 and 6 on
            m_solenoids[3].set(false);
            m_solenoids[4].set(false);
		} else if (numloop_within_second == (GetLoopsPerSec() * 5 / NUM_KITT_POSITIONS)) {
			// position 6; solenoids 2 and 7 on
    int GetLoopsPerSec() {
        return 20;
	 * Demonstrate handling of joystick buttons
	 * This method expects to be called during each periodic loop, providing the following
	 * capabilities:
	 * - Print out a message when a button is initially pressed
	 * - Solenoid LEDs light up according to joystick buttons:
	 *   - When no buttons pressed, clear the solenoid LEDs
	 *   - When only one button is pressed, show the button number (in binary) via the solenoid LEDs
	 *   - When more than one button is pressed, show "15" (in binary) via the solenoid LEDs
	public void DemonstrateJoystickButtons(Joystick currStick,
									boolean[] buttonPreviouslyPressed,
									String stickString,
									Solenoid solenoids[]) {
		boolean outputGenerated = false;		// flag for whether or not output is generated for a button
		int numOfButtonPressed = 0;		// 0 if no buttons pressed, -1 if multiple buttons pressed
		/* Iterate over all the buttons on the joystick, checking to see if each is pressed
		 * If a button is pressed, check to see if it is newly pressed; if so, print out a
		 * message on the console
			if (currStick.getRawButton(buttonNum)) {
				// the current button is pressed, now act accordingly...
				if (!buttonPreviouslyPressed[buttonNum]) {
					// button newly pressed; print out a message
					if (!outputGenerated) {
						// print out a heading if no other button pressed this cycle
						outputGenerated = true;
						System.out.println("button pressed:" + stickString);
					System.out.println(" " + buttonNum);
				// remember that this button is pressed for the next iteration
				buttonPreviouslyPressed[buttonNum] = true;
				// set numOfButtonPressed appropriately
				if (numOfButtonPressed == 0) {
					// no button pressed yet this time through, set the number correctly
					numOfButtonPressed = buttonNum;
				} else {
					// another button (or buttons) must have already been pressed, set appropriately
					numOfButtonPressed = -1;
			} else {
				buttonPreviouslyPressed[buttonNum] = false;
		// after iterating through all the buttons, add a newline to output if needed
		if (outputGenerated) {
			System.out.println("\n");
		if (numOfButtonPressed == -1) {
			// multiple buttons were pressed, display as if button 15 was pressed
			DisplayBinaryNumberOnSolenoidLEDs(15, solenoids);
		} else {
			// display the number of the button pressed on the solenoids;
			// note that if no button was pressed (0), the solenoid display will be cleared (set to 0)
			DisplayBinaryNumberOnSolenoidLEDs(numOfButtonPressed, solenoids);
	 * Display a given four-bit value in binary on the given solenoid LEDs
	void DisplayBinaryNumberOnSolenoidLEDs(int displayNumber, Solenoid[] solenoids) {
		if (displayNumber > 15) {
			// if the number to display is larger than can be displayed in 4 LEDs, display 0 instead
			displayNumber = 0;
		solenoids[3].set( (displayNumber & 1) != 0);
		solenoids[2].set( (displayNumber & 2) != 0);
		solenoids[1].set( (displayNumber & 4) != 0);
		solenoids[0].set( (displayNumber & 8) != 0);
Any help would be greatly appreciated
