Go to Post If you can spare 2 minutes (And I know you can, because the season’s over and you’re STILL on Chief Delphi) - LVMastery [more]
Unread 16-02-2013, 13:15
Team4641 Team4641 is offline
FRC #4641
Team4641 is an unknown quantity at this point
Festo Solenoid Control Question
We are having trouble controlling our Festo Solenoid from the Analog Breakout Card. It appears the Festo runs off of 12V control signals, but we are only able to generate 5V outputs from our breakout card.
Currently we have the controller outputs directly connected to the PWM inputs on the Festo. Do we actually require a Spike relay in between in order to control with 12V signals? Or is there a way in LabVIEW to change the outputs from 5V to 12V instead?
In the FRC documentation we see the connections straight from the Analog Breakout Card to the Solenoid, however in their connections they are actually using an SMC as opposed to our Festo.
TIA for the help.
Unread 16-02-2013, 13:56
TogetherSword8 TogetherSword8 is offline
FRC #0888 (Robotiators)
Rookie Year: 2012
TogetherSword8 is an unknown quantity at this point
Re: Festo Solenoid Control Question
I know exactly what you are talking about. we just hooked our slot on the crio to an output that you would hook up a spike to, so it is on its own breaker. it seems to work fine so far.
Unread 16-02-2013, 14:31
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
The Festos that have come in the Kit the past few years are 24v devices.
Solenoids connect to the Solenoid breakout, NOT the Analog Breakout.
Note that the Solenoid Breakout is shorter than the Analog Breakout, and the Solenoid Module has two rows of green status LEDs.
The Solenoid Breakout can be wired with either 12v or 24v directly from the Power Distribution Panel. Pick the right one for your solenoids.
The 24v Festo looks like this:
If you really have a 12v solenoid (not a Festo) then it can be wired to a Spike and controlled in code as a Relay.
Unread 16-02-2013, 20:11
FRC #4641
Thanks for the response both of you.
We discovered that we actually received two Analog Breakout Boards instead of receiving a Solenoid Breakout Board. As a result, our outputs were 5V. If we were able to use a Solenoid Breakout Board as in Mark's response I believe it would resolve all of our issues.
Thanks again for the help.
Unread 16-02-2013, 22:26
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Mark,
Festo dual solenoid valves can have either 12V or 24VDC solenoid coils. There is white lettering calling out the required activation voltage. Most (all?) of the KoP valves were 24v and Andymark was selling 12v ones (only?) for some time.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 16-02-2013, 22:35
Just Itinerant
Originally Posted by Bill_B View Post
Mark,
I glossed over that possibility, as this is a rookie team who probably doesn't know the difference yet. They have limited experience with FRC solenoids and I conjecture that they've only ever seen the Festo 24v solenoids that came in this year's kit.
The coils will be marked as 12v or 24v so you can double check.
Unread 16-02-2013, 22:43
Team3266Spencer's Avatar
Team3266Spencer Team3266Spencer is offline
Team Captain and Lead Programmer
AKA: Spencer Lanman
FRC #3266 (Robots-R-US)
Rookie Year: 2012
Team3266Spencer is an unknown quantity at this point
Were having trouble with one of our double solenoids as well, we believe its wired correctly and have the same code that's working on our practice robot, using the double solenoid. We believe we can feel vibrations when we power it but the valve does not change.
2012: Buckeye Regional, Queen City Regional, Human Player
2013: Queen City Regional, Buckeye Regional, Crossroads Regional
Shooter Operator
2014: Crossroads Regional, Queen City Regional
Catapult Operator
2015: Georgia Southern Classic Regional (Winner), Queen City Regional
Chainsaw Operator
Want to talk? TeamSpeak: team3266.noip.me
Unread 16-02-2013, 22:48
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Check your flow-control.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 16-02-2013, 22:54
Just Itinerant
The connection of the solenoid wires at the Solenoid Breakout could be reversed.
Do the green status lights on the Solenoid Module respond to the controls correctly? That'll guarantee that your code is correct.
Do the status lights on each of the solenoid coils light up when you activate each?
The lights there should correspond to the Solenoid Module status LEDs.
Do you have pressure in the system?
The solenoids are pilot pressure driven, meaning they must have ~30psi to operate.
Is the solenoid plumbed properly?
Input goes into the single-fiitting side in the photo above. Two cylinder outputs come out the double-fitting side.
Unread 16-02-2013, 22:55
FRC #2170
There are indicator LEDs on each of the solenoid coils. There are also indicators for each of the 8 channels on the solenoid breakout in the cRIO. If they are all going green, solidly, then I'd guess the wiring and programming are correct. You can also try manual activation of the valve(s) by pushing the blue "button" on the valve. If nothing happens when you do that, there is an air circuit problem.
Unread 16-02-2013, 22:57
AKA: Spencer Lanman
Rookie Year: 2012
Yes the green lights I know were all properly functional. We'll have to search for the blue button tomorrow.
Shooter Operator
Catapult Operator
Chainsaw Operator
