Go to Post Last year we saved a ton of money by using a good bit of square tubing for the frame of our robot, square tubing is a lot cheaper then C channel. We get to use so much raw material that the cost should go down in certain places. - Derrick Maust [more]
Unread 16-02-2013, 14:58
valeriemoore valeriemoore is offline
FRC #2022
Team Role: Mechanical
valeriemoore is an unknown quantity at this point
Are AM-0914 motors legal?
We got a AM-0914 motor and corresponding gearbox in the kit of parts, but the serial number isn't on the list of legal motors. Is the motor legal?
Unread 16-02-2013, 16:06
Liz Smith's Avatar
Liz Smith Liz Smith is offline
believes in robots
AKA: Pika1579
FRC #3940
Liz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond repute
Send a message via AIM to Liz Smith
Re: Are AM-0914 motors legal?
The part number am-0914 refers to the gearbox and the motor. The included motor is an am-2161 which is on the allowable motors list in the game manual.
Alumna of 555 Mentor of 3940
Volunteering since 2004: Say hi to me at events!
Applications Engineer
AndyMark, Inc.
Unread 12-03-2013, 19:49
choas5000 choas5000 is offline
Programming
AKA: Nick Little
FRC #4640 (Era4640)
Rookie Year: 2013
choas5000 will become famous soon enoughchoas5000 will become famous soon enough
how do you use them
Unread 12-03-2013, 20:11
Grim Tuesday's Avatar
Grim Tuesday Grim Tuesday is offline
AKA: Simon Bohn
FRC #0639 (Code Red)
Rookie Year: 2010
Grim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond repute
Originally Posted by choas5000 View Post
how do you use them
What are you asking?
Unread 12-03-2013, 20:59
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Team Role: Teacher
how do you use them
From the PG-71 page on the AndyMark website, which also lists physical and performance specifications:
If you wish to use it in another gearbox, use the recommended 16 tooth gear.
If you wish to use it to drive chain, use the recommended 16 tooth sprocket.
If you wish to use it to direct drive something, use the recommended hub.
If you wish to mount it to a surface perpendicular to the output shaft, use four M4x0.7 screws.
If you wish to mount it to a surface skew to the output shaft, use the recommended gearmotor bracket and the aforementioned screws.
I've put in an informal request for them to offer their gearmotors with a hex output shaft; maybe that option will be around for the 2014 season.
Also, treat the back end with care. Our team has a nasty habit of accidentally snapping off the spade connectors.
Hi!
