Go to Post FRC is not worth giving up your grades. - Gregor [more]
Unread 16-02-2013, 18:42
C.I.S. C.I.S. is offline
FRC #4607 (Coalition of Independant Students (C.I.S.))
Rookie Year: 2013
C.I.S. is an unknown quantity at this point
cRIO & Solenoids
Do we need anything other than the cRIO to power 24v solenoid valves? In other words, do we need an additional converter, if so where to purchase in short order?
Unread 16-02-2013, 22:02
DonRotolo's Avatar
Back to humble
FRC #0832
Re: cRIO & Solenoids
In addition to a cRio, you need a pneumatics module and breakout for the top of it. That is all. 24 volts comes from the power distribution board.
Unread 19-02-2013, 09:13
Bryce Klang Bryce Klang is offline
FRC #3313 (Mechatronics)
Team Role: Student
Rookie Year: 2011
Bryce Klang is an unknown quantity at this point
no you don't need anything else, like someone already said all you need is a solenoid break out and then you wire it to the 24v slot on the power distribution this is located at the back of the the board (saying that the terminals are the front)
