Go to Post You can be extra safe or you can be competative - its your choice. - Raul [more]
Unread 16-02-2013, 21:49
tux tux is offline
AKA: Lee Harr
FRC #3842 (Shock-a-Bots)
tux is an unknown quantity at this point
Solenoid Breakout required?
The control system setup documentation says to install a solenoid breakout module in the cRio, but I can't see anything requiring that module in the manual.
If we are not using any solenoids is that module required?
If it is required, how is it powered when using a cRio II? The version 1 has 4 spaces available on the power plug, but the version 2 has only 2 spaces available. My understanding is only 1 wire may be plugged in to any 1 space on a connector.
Thanks for any assistance.
