Go to Post When your team becomes ubiquitous with the phrase "Always a bridesmaid, never the bride" - Peyton Yeung [more]
Unread 16-02-2013, 22:17
jojoguy10's Avatar
jojoguy10 jojoguy10 is offline
Programming/Controls Mentor
AKA: Joe Kelly
FRC #0997 (Spartan Robotics) and FRC #2990 (Hotwire Robotics)
Rookie Year: 2010
jojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant future
Volts in Driver Station reads 00.00
My team is having a strange problem. When we turn on our robot, we can't see the correct voltage on the driver station. All it reads is 00.00 all the time. We have triple-checked that the jumper is the the outer two pins on the analog module and the module is the correct one (we used it on last years competition robot which showed the correct voltage). We have re coded our code twice, still the same result. We are using a 4-slot cRIO and have re-imaged that several times.
Anyone have any ideas or having this issue?
