Go to Post You miss 100% of the shots you don't take. - AdamHeard [more]
Unread 17-02-2013, 11:50
Mr. 1033's Avatar
Mr. 1033 Mr. 1033 is offline
AKA: Paul E. Lathrop
FRC #1033 (Team CLUTCH)
Team Role: Coach
Mr. 1033 is a jewel in the roughMr. 1033 is a jewel in the roughMr. 1033 is a jewel in the roughMr. 1033 is a jewel in the rough
Compressor to Pressure Switch
Hey Teams,
Just a quick and silly question for you.
My team built the Andy Mark pneumatic set up that can be found at the following website:
http://www.andymark.com/product-p/am-2000.htm
The picture shows a 4 way union where the pressure switch is mounted.
My rules team member showed us the picture from the game manual where it says that the system must look like their example circuit. In the circuit they have the pressure switch mount later in the system.
It makes sense that the switch is after the tanks to me but I could be wrong.
Haven't used pneumatics in almost 5 years so we're a little rusty.
Thanks,
1033
Unread 17-02-2013, 11:59
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Rookie Year: 1999
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Re: Compressor to Pressure Switch
As long as the pressure switch is on the high side before the pressure regulator its locations doesn't matter. When they tell you it needs to look like the example they mean items in similar order.
Unread 17-02-2013, 12:04
Mr. 1033's Avatar
Team Role: Coach
Awesome.
Thanks a million!
We def appreciate it!
Unread 17-02-2013, 12:06
Andrew Bates's Avatar
Andrew Bates Andrew Bates is offline
AKA: Bates
FRC #0125 (NUTRONS)
Team Role: Mechanical
Andrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond repute
Your system must look like the system in the manual in that all components are effectively in the same place. The Pressure switch needs to be anywhere on the High side of the system. See R87.
The pressure relief valve however needs to be directly connected to the compressor per rule R86.
ME Student at Northeastern University, Captain of the NUTRONs #125 FRC
Former member of VEXELLENT and Cranbrook Robotics
