Go to Post Every team in FIRST can make this choice. Be positive, help others, and work like a maniac behind the scenes. This approach will bring you joy and satisfaction, whether you win or not. - OZ_341 [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 17-02-2013, 13:12
mattachew12 mattachew12 is offline
FRC #3597
mattachew12 is an unknown quantity at this point
error in speed control mode
I'm using two CANJaguars, but only testing on one for the moment, and when I try to set it to the speed control mode, it doesn't give speeds anywhere near what I want, and usually throws an error too
>>>>ERROR: status == -1073807298 (0xBFFF003E) in Read() in C:/WindRiver/workspace/BlackJagBridgePlugin/SerialPort.cpp at line 216
I'm using java and have a quadrature encoder attached to a gearbox, which I believe is causing the odd values, but I don't know why the error is being thrown. Sometimes it works, other times it doesn't. It seems to have something to do with my PID values (20.0, .1, .01) , but I'm not sure. Any ideas?
Error 404-Signature Not Found
