Go to Post Pneumatic components always give me gas... - Alan Anderson [more]
Unread 17-02-2013, 16:11
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
Team 3038 Full Court Shooter and Climber
We are planning to put a gear tooth sensor to make the shooting WAY more accurate. Our climber is flawless out of the 10-15 matches we played we didnt climb once due to not getting their in time. Also all the shots made are from our robot at the feeder station. Enjoy
http://www.youtube.com/watch?v=Q7cvh...ature=youtu.be
Sorry for the delay I forgot about the privacy setting on facebook -_- So i uploaded it to youtube.
ALSO:::: Our robot is off screen for the shots its not the red robot. It is the middle robot that hangs unlabeled with blue bumpers .
Unread 17-02-2013, 16:14
Re: Team 3038 Full Court Shooter and Climber
Check your facebook privacy settings or just post somewhere public.
Unread 17-02-2013, 21:12
PVCpirate's Avatar
PVCpirate PVCpirate is offline
FRC Data Nerd
AKA: Anthony Jennings
FRC #1058 (PVC Pirates)
PVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud of
Not to ignore your robot which is great, but how accurate was the red robot that was also shooting full-field? I'm interested because if two robots at the same pre-ship competition could do this accurately, it says a lot about how common it might really be this year.
My accomplishments with 1058:
2010 - Granite State Regoinal Winners, Galileo quarterfinalists, IRI quarterfinalists
2012 - GSR Chairman's Award winners
An incredible four years I will never forget
Unread 17-02-2013, 21:14
They got 11 shots in the two point goal they were extremely accurate but they have had about 1-2 weeks we get the timing down on their shooter and feeding they dont have any encoders or sensors it just flies straight into the two point shot.
Unread 17-02-2013, 21:21
PVCpirate's Avatar
FRC Data Nerd
Thanks for the info, sounds like this will be huge at most events.
Unread 17-02-2013, 21:22
yes once my team gets the gear tooth sensor working we are hoping to shoot that well.
Unread 17-02-2013, 21:47
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
What was the accuracy of both of those bots, they don't seem very good....
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Unread 17-02-2013, 22:10
The red one in the camera was 60% id say and ours is really low right now but we are planning on putting a gear tooth sensor and implement a PID loop to get the shooter shooting at the right speed every time
Unread 17-02-2013, 22:33
nikeairmancurry's Avatar
nikeairmancurry nikeairmancurry is offline
FF - TeamSuperPowerMatic
AKA: Nicholas
FRC #0313
nikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond repute
What motors and wheels did you use on your shooter, if you don't mind to answer.
Team Member- 326 2006-2009
Team Mentor- 326 2010-2013
Team Mentor- 313/5220 2014-??
Unread 17-02-2013, 22:44
1 Mini CIM with a planetary gear box with a 1-1 gear ratio.
Unread 17-02-2013, 22:49
topgun's Avatar
topgun topgun is offline
FRC #2846 (FireBears)
topgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant future
Why run it through the gear box if it's 1-1? Why not run it direct to the wheel?
-T
Unread 17-02-2013, 22:50
wilsonmw04's Avatar
wilsonmw04 wilsonmw04 is offline
Coach
FRC #1086 (Blue Cheese)
Team Role: Teacher
Rookie Year: 2007
wilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond repute
I don't mean to be a downer, but I didn't see chains on those goals. Do you expect to be as successful with a complete competition goal?
Currently: Coach FRC 1086/FTC 93
2006-2011 Coach FRC 2106/FTC 35
If you come to a FRC event to see a robot competition, you are missing the point.
