Go to Post Y'know... I think I'd much rather have big balls than hang myself... - FotoPlasma [more]
Unread 18-02-2013, 02:16
ww2freak8 ww2freak8 is offline
FRC #4345
ww2freak8 is an unknown quantity at this point
Smile Re: Programming a compressor
Originally Posted by plnyyanks View Post
That doesn't sound right. You should be getting +12, -12, or 0. Check the input wiring - it sjhould go a terminal on the PDB protected by a 20 amp breaker.
If it's solid orange, that means it's outputting neutral (zero volts). If it's trying to get your compressor to run, it'll turn green (forward). There should be a PWM wire between the spike and Relay port 3 on your digital sidecar (like you specified in code)
When the pressure going through the pressure switch is <120 psi, there will be an open circuit between the two wires coming off it (which should go to DIO 14, like you specified in code). That circuit will close when the pressure reaches 120 psi. This tells the cRIO to turn off the compressor.
Take a look at the Signal Wiring Diagram and the Power Wiring Diagram to see how to wire the pressure switch and a spike relay.
Thanks! I'll make sure all that is good tomorrow, hopefully can get everything working before midnight
Unread 19-02-2013, 19:59
FRC #4345
so looks like it was a bad spike relay. compressor works fine now and even more issues arise today such as the trigger button not working even though before it did and now our motor that is suppose to be triggered by it turns on when teleop is enabled =/
