Go to Post I will never forget Dean's opening lines: "I want you to know that I am here under protest. I believe that everything you are doing here is repugnant and ethically wrong. And now I am going to tell you why..." And for the next 35 minutes, that is exactly what he did. - dlavery [more]
Unread 17-02-2013, 19:54
admrialkunkka admrialkunkka is offline
FRC #2815
admrialkunkka is an unknown quantity at this point
We cannot find Windows.h
Our team has never used image processing before. We are using windriver and the code generated for us by the NI Vision assistant and the code for processing the axis camera image was exported as c so we changed it to c++. We then changed the import of the machine file to #include "nimachinevision.h"
but when we build the code we get, #include <windows.h>, windows.h: No such file or directory. Where can I find the windows.h file?
Unread 17-02-2013, 20:33
connor.worley's Avatar
connor.worley connor.worley is offline
FRC #0973 (Greybots)
Rookie Year: 2010
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Re: We cannot find Windows.h
You will need to download the Microsoft Windows SDK. http://www.microsoft.com/en-us/downl...s.aspx?id=8279
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 18-02-2013, 11:42
FRC #2815
Smile Re: We cannot find Windows.h
Thank you
Unread 18-02-2013, 12:19
FRC #2815
How do we apply it to windriver?
Unread 18-02-2013, 21:28
Itamar's Avatar
Itamar Itamar is offline
FRC #1943 (NeatTeam) & FRC #4590 (GreenBlitz)
Rookie Year: 2010
Itamar is an unknown quantity at this point
Try commenting out the "windows.h" include and adding the following:
Code:
#include <stdio.h>
If I remember correctly, the function included in windows.h and used in the image processing code is "sprintf", which is also available in "stdio.h". (It makes sense that windows.h isn't available since you're deploying the code on VxWorks, not Windows)
