Go to Post Scouting wins championships folks...not draft orders. - Andy Grady [more]
  #16   Spotlight this post!
Unread 19-02-2013, 07:53
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
Re: Victor 888 "y" cable issues
Originally Posted by theawesome1730 View Post
I do not however understand how a victor running 1% output can put out 12 volts.
Was that measured unloaded?
I agree that the cause of this is almost certainly the added load of a second Victor affecting the rise and fall times of the PWM signal enough to land just outside the 888s deadband. Try calibrating the Victors while they are attached to the Y cable and I expect the problem will go away.
  #17   Spotlight this post!
Unread 19-02-2013, 09:42
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Here's a graph of an 884's output voltage vs input pulse width, with the output essentially unloaded (1500 ohms).
  #18   Spotlight this post!
Unread 19-02-2013, 10:01
Racer26 Racer26 is offline
Racer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond repute
I found when working with 4343 that we had to calibrate our Victor 888's on the Y cables to get them to behave nicely. Took a few tries to get "off" to be "off" and not "on just a hair"
