Go to Post Me: Hi, Honey - I'm home! Wife: Must have shipped the robot today, huh? - meaubry [more]
Unread 02-18-2013, 09:55 AM
Norfen Norfen is offline
FRC #0302 (The Dragons)
Rookie Year: 2011
Norfen is an unknown quantity at this point
BoundaryException on Cypress Board
We use a cypress board for our co-driver, and it recently started throwing an exception whenever we try to access a certain switch, however it had worked before. We traced back through our changes and can't seem to find the problem.
It throws
Code:
edu.wpi.first.wpilibj.util.BoundaryException: Value must be between 1.0 and 6.0, 7.0 given
when called by
Code:
DriverStation.getInstance().getEnhancedIO().getButton(7)
and we can't figure out why. Help?
Unread 02-18-2013, 03:22 PM
Cel Skeggs Cel Skeggs is offline
Robot Software Manager Alumnus
AKA: Previously known as Colby
FRC #1540 (The Flaming Chickens)
Cel Skeggs is a glorious beacon of lightCel Skeggs is a glorious beacon of lightCel Skeggs is a glorious beacon of lightCel Skeggs is a glorious beacon of lightCel Skeggs is a glorious beacon of lightCel Skeggs is a glorious beacon of light
Re: BoundaryException on Cypress Board
According to the documentation for DriverStationEnhancedIO, the button index given to getButton must be in the range of 1 to 6. You are passing 7 to this function.
Are you sure that you mean to use button seven?
Unread 02-19-2013, 12:08 PM
Rookie Year: 2011
Does this mean that we can only use six buttons? I swear we've used more in previous years.
Unread 02-19-2013, 12:16 PM
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Are you sure that in the past you didn't connect your own buttons to digital inputs, and use the getDigital() method to read them? There are 16 digital IOs that can be configured as inputs.
Unread 02-19-2013, 10:50 PM
Rookie Year: 2011
Switching to getDigital() does it, thank you. I guess i got mixed up between EnhancedIO and Joystick.
