Go to Post It's a hunch, based on engineering intuition; there are too many hard-to-quantify variables to do any accurate calculations. Looking for some experimental corroboration or refutation. - Ether [more]
Unread 18-02-2013, 10:40
Programmer_Sean Programmer_Sean is offline
AKA: Sean Hoyt
FRC #3690 (GORT)
Rookie Year: 2011
Programmer_Sean is an unknown quantity at this point
Roborealm Image in Dashboard
I have been working on getting a processed image from roborealm to appear on are FRC dashboard, i have succeed.
This the line that is in are Dashboard_main.vi
As you can see there are two subvi's, roborealm image string.vi asks roborealm for the image in a string, it then goes to the decodejpg.vi which is just a copy of some code i found in the "WPI_CameraRead MJPG.vi" which turns it into a image which is then displayed on the dashboard.
Roborealm Image String
Decode Jpg
I have also attached the vi that i just talked about just unzip the .zip file to retrieve them.
I hope this helps people, i posted this because i could not find anything on the internet that shows how to get the Image on the dashboard in labview all i could find was for java and C++.
Unread 18-02-2013, 21:38
Re: Roborealm Image in Dashboard
The only thing that I'll comment on that might be improved is to use the actual WPILib JPEG decoder without dropping down that low level.
vi.lib\Rock Robotics\WPI\Camera\WPI_CameraDecodeJPEGString.vi
Greg McKaskle
Unread 18-02-2013, 22:04
AKA: Sean Hoyt
FRC #3690 (GORT)
Rookie Year: 2011
Thank you for the reply my only question is what is the difference between the two because they both have the same inputs and outputs. The decoder i show is a exact copy of what is done in the dashboard project.
Unread 19-02-2013, 04:17
The unique stuff you wrote for RR is a nice thing to give away, and the copy of the jpeg stuff is something everyone already has. It is part of WPILib.
The difference is that there are now two subVIs that are functionally the same with almost the same name. It wasn't clear to me why the copy was constructed. If it was for practice, and understanding, that is fine, but I suspect it will cause confusion over time, and it would be somewhat better to use the original.
Greg McKaskle
Unread 06-03-2013, 11:55
JoesephWhite's Avatar
JoesephWhite JoesephWhite is offline
Alumni, Mentor for 2341 & 4612
FRC #4612 (RoboRockets)
Rookie Year: 2010
JoesephWhite is an unknown quantity at this point
I see that your code says the camera is the Kinect, how are you getting the data from the Kinect to the driver station?
