Go to Post Winning the robot part of the competition is not about learning or doing unneccesary work. It works just like "winning" in industry. - Max Lobovsky [more]
Unread 18-02-2013, 12:03
y-aji y-aji is offline
FRC #3734
y-aji is an unknown quantity at this point
Disabling auto-IP update "feature" in drivers station
Is there a way to stop the IP from being changed when you enter the drivers station each time it opens?
It constantly screws with all the computer network cards and we have it in a controlled environment where we don't need help with the IP address.
Unread 18-02-2013, 12:14
kjohnson's Avatar
kjohnson kjohnson is offline
Insert Clever Title Here
AKA: Kyle J.
FRC #1610 (BOT)
kjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond repute
Re: Disabling auto-IP update "feature" in drivers station
On the Setup tab of the Driver Station, select "Choose NIC" directly under where you enter your team number. From there you can choose or disable the network interface that the DS software sets.
Unread 18-02-2013, 13:21
FRC #3734
Wewt! Thank you!
