Go to Post FIRST is an organization where you leave lasting impressions on people you don't even know. - rtfgnow [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 24-06-2002, 00:09
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
archiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond repute
So you want to stall a Globe Motor...
Posted by Joe Johnson.   [PICTURE: SAME | NEW | HELP]
Engineer on team #47, Chief Delphi, from Pontiac Central High School and Delphi Automotive Systems.
Posted on 10/17/2000 6:55 PM MST
I have just performed an experiment that I had intended to do before I published the Applicaton Notes, but ran out of time.
Basically, I have a recomendation for teams that want to stall a Globe motor but can't do it with the stuff in the kit.
Here is how.
Use a Ruland Rigid Coupling to connect the short Globe motor shaft to a longer 1/4 inch dia. shaft. Then use TWO Trantorques to connect ONE sprocket to this extended shaft. The combination of the two Trantorques provide enough grip to the 1/4 inch shaft to stall the Globe motors.
This trick can be used any time you want to provide more twist to a 1/4 inch shaft than a single Trantorque can provide. I was surprised at how well this worked.
What you do with that extra torque is up to you.
Good Luck.
Joe J.
P.S. I will put a picture of my experimental set up in due time.
This message was archived from an earlier forum system. Some information may have been left out. Start new discussion in the current forums, and refer back to these threads when necessary.
#0047 (ChiefDelphi)
Re: So you want to stall a Globe Motor...
Posted by Raul.   [PICTURE: SAME | NEW | HELP]
Engineer on team #111, Wildstang, from Rolling Meadows & Wheeling HS and Motorola.
Posted on 10/24/2000 11:23 AM MST
In Reply to: So you want to stall a Globe Motor... posted by Joe Johnson on 10/17/2000 6:55 PM MST:
I thought the coupling was only rated for 30 to 60 in-lbs? If so, how can it transmit the stall torque?
Raul
[IMG] code is Off
Globe Motor archiver 2000 4 24-06-2002 00:15
Globe Motor archiver 2000 0 24-06-2002 00:15
Globe Motor and Thermal Protection archiver 1999 0 23-06-2002 22:03
Globe motor specs patrickrd Motors 1 06-01-2002 20:50
Help! Need a Globe Motor Dodd Motors 0 24-07-2001 11:57
