Go to Post I guess that some people don't understand that no means no. - Steve W [more]
Unread 18-02-2013, 17:36
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
Re: Over weight robot
Originally Posted by Shane 2429 View Post
drill anything not structural and if that doesn't help any drill more holes between those holes also look for anything not entirely necessarily and see if can removed
so in short drill holes drill holes and drill more holes
Calculate the mass of the holes before you drill any. Use the volume of a cylindrical hole times the density of the material you're thinking of drilling. This should only take a few minutes to estimate.
Additionally, some cost-benefit analysis of your mechanisms and drilled holes is in order. Are you better of by sacrificing a mechanism and just getting the robot finished, or by taking the next day or so to drill holes in things?
And this goes without saying: everyone participating in your decision must understand the weight limits in the rules.
Unread 18-02-2013, 21:39
DonRotolo's Avatar
Back to humble
FRC #0832
Originally Posted by Priyesh69 View Post
We are taking out the manifold and the compressor
Queston: will we have enough air
Enough air for what? If you have 2 plastic tanks and one cylinder like in the photo, probably yes, for one time. If you have 2 cylinders and others, then maybe not. TRY IT AND SEE.
Unread 18-02-2013, 21:44
giantmidget31's Avatar
giantmidget31 giantmidget31 is offline
Eat robots, build waffles.
FRC #0555 (Montclair Robotics)
Team Role: Electrical
Rookie Year: 2007
giantmidget31 is an unknown quantity at this point
We were very overweight, so we took off our shooter! It wasn't working that well, and we were easily able to turn our disc lifter into a level 1 dumper, which may even score more points than the level 3 shooter, and we still have our climber.
Unread 19-02-2013, 08:01
Swampdog Swampdog is offline
FRC #3381
Swampdog has a spectacular aura aboutSwampdog has a spectacular aura aboutSwampdog has a spectacular aura about
Holes Help. We lost 3 lbs last night. Do you have Aluminum gears in your gear boxes? That can be .4-.8 lbs depending on gear boxes.Do you have the small compressor? Do you need to motors on your shooter? How many drive sims? If 4 do you really need 4? Are you sure about your scale? Are you picking up off the floor? Do you have to? Seems like we have a fat robot every year usually don't name him until he is under. 119.9 is all it takes. Good luck.
Unread 19-02-2013, 09:47
Jibri Wright's Avatar
Jibri Wright Jibri Wright is offline
FRC #1781 (Electric Eagles)
Team Role: CAD
Rookie Year: 2011
Jibri Wright will become famous soon enough
Try replacing a compressor with a mini compressor, use a smaller c-Rio (we normally use the 4-block one), attach electronics to polycarbonate and Velcro them on.
You know someone likes something when after doing it a million times, they still marvel at it as if it was the FIRST.
Greatness asks how can I make it better. Genius asks how can I make it different.
Unread 19-02-2013, 13:08
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
A few things:
-Replace all of the sheet metal with similar thickness polycarbonate.
-I can't see your battery mount, but based around the way the bot is built, it's probably overbuilt, but easy to modify
-Drop all the clips that hold in the pneumatic tanks and use 3-4 zipties.
Best of luck!
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 19-02-2013, 14:18
akgsteelers's Avatar
akgsteelers akgsteelers is offline
Manufacturing/Pit Lead
AKA: Andrew
FRC #0384 (Sparky)
Team Role: Mechanical
Rookie Year: 2012
akgsteelers is an unknown quantity at this point
It looks like you have a lot of fasteners on your robot. If they are stainless steel or steel. if they are you could replace a lot of those with nylock or aluminum.
Hope this post helps.
SPARKY 384
Unread 19-02-2013, 21:14
FlusteredRookie FlusteredRookie is offline
FRC #4423
Rookie Year: 2013
FlusteredRookie can only hope to improve
Exclamation Re: Over weight robot
Our robot also has a weight issue... How strictly is the 120 pound rule enforced?
Unread 19-02-2013, 21:15
Hallry's Avatar
Hallry Hallry is online now
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
Rookie Year: 2010
It's a rule in the Game Manual. If you don't meet the rule, your robot is illegal and thus can't compete. And yes, all robots are weighed, at each competition.
Unread 19-02-2013, 10:09
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
Originally Posted by Gregor View Post
...You can easily shed 10 lbs with just drilling holes, don't do anything drastic.
I disagree; 10 pounds worth of holes is very drastic. We've never been able to lose more than 2 lbs just by swiss-cheesing. Since some of the materials in the pictures look like they are overly heavy, maybe the holes could add up to 4 or 5 pounds.
I would look for structural parts that don't need to be so heavy-duty. Such as C-channel or 80-20 that could be replaced with angle bar, or solid 1/4" plastic or plywood that could be thinner or corrugated.
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
Unread 19-02-2013, 11:07
tickspe15's Avatar
tickspe15 tickspe15 is offline
Purdue University
AKA: Spencer Tickman
FRC #1747 (Harrison Boiler Robotics)
tickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant future
Remake your shooter with lighter materials. Last year we were 20 pounds over we drilled 1023 holes and only lost 8 pounds. The bulk of our weight loss came from switching to lighter ,materials. I recommend you do the same
Unread 19-02-2013, 11:19
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
10 pounds is a lot to lose, but you can do it. Remember that you don't need to lose it all at once, small cuts add up!
First, think of how much you actually need to run your pneumatics, we have used precharged in the past and as long as you don't have a leak it works well. I would recommend taking off the compressor before removing airtanks, it is heavier and less necessary. If you are using a full sized compressor, you could start by switching to the mini one, that will save you about 2 pounds. If you have the mini one and you take it off that will be about the same.
Swiss cheese is good. Find places that you can drill holes or enlarge ones that are not critical or in use. This won't do a ton, but you could probably get 3-4 pounds out of it if you really stretch it. I would say that 3 is a reasonable goal.
Look at all of your bolts. Find which ones are extraneous and take them out. Like the post above said, you probably don't need 3 1/4-20's to hold up the 1/2 pound airtank. 2 would probably be sufficient, even 1. Heck, you could probably get by with zipties for it. That's what we are using. Find all the bolts that extend far past the nuts holding them on. switch them to the smallest possible size that you can use while still going through the nut. This could add up to about 2 pounds depending on how much you guys take out.
Find material that you don't need and remove it. This is basically just drilling holes but bigger. if you have a full plate that a frisbee will slide on, you really only need the ends, take out the middle. When possible, try using 1/16" metal instead of 1/8". It's tough to tell from the picture but this might be able to get another 2 pounds for you guys.
You probably won't want to do this, but you could also find electrical wires that are too long and shorten them to just what you need. This will cut down a pound or two and eliminate any rat's nest you might have.
As a last resort, fill your air tanks with helium before weigh in
Good luck!!!
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Unread 18-02-2013, 16:15
Patrick Flynn Patrick Flynn is offline
Rookie Year: 2010
Patrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond repute
Since you are currently 10lbs over drilling holes is going to be difficult thats a lot of holes. I dont know if there is even room to drill that many holes from your pictures.
I would look over what materials your using, are you using a 1/2'' plate where something much smaller could be use?
Like posted above make sure your battery and bumpers weren't included in that weight.
Unread 18-02-2013, 16:19
Priyesh69 Priyesh69 is offline
FRC #3988
Priyesh69 is an unknown quantity at this point
Our arms are pretty heavy 7lbs each. In this short time we cant get smaller piston.
  #15   Spotlight this post!
Unread 18-02-2013, 17:15
Depending on when your regional is, you have time to order lighter ones now that you can drop in during practice day of your event. You also have the withholding allowance....
