Go to Post Mastering simple skills can be a complex challenge. - Petey [more]
Unread 18-02-2013, 17:22
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Rookie Year: 2011
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Re: Over weight robot
This is a bit of out an out there idea but you can replace the AM kit frame corner brackets with 1/8 plate gussets. EX: http://www.chiefdelphi.com/media/photos/38516 And use rivets instead of bolts.
Edit: http://www.chiefdelphi.com/media/photos/38390 cad files are in this.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 18-02-2013, 17:34
jwallace15's Avatar
jwallace15 jwallace15 is offline
What am I going to do with my life?
AKA: Wally
FRC #0068 (Truck Town Thunder)
Rookie Year: 2013
jwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud of
I know you guys are short on weight, but are your accumulators plastic?
If they are, check this out...
It may be a good idea to keep the plastic accumulators, but please see the risk involved with it.
J Wallace IV
Truck Town Thunder
Just a college student now.
Unread 19-02-2013, 14:15
Orion.DeYoe Orion.DeYoe is offline
FRC #5413 (Stellar Robotics)
Rookie Year: 2011
Orion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to behold
Please realize that this was a user error. There is no way that that tank burst by itself. There is nothing wrong with plastic tanks. Most likely the fittings on the tank were over tightened or it was dropped. Please try not to cause panic and bias towards a product because of one team's mistakes.
Unread 19-02-2013, 14:11
Rookie Year: 2011
Unhappy Re: Over weight robot
Originally Posted by Priyesh69 View Post
We now have 130lbs on our robot and have just kept the stric basic(2 arms, shooter). We don't know where to cut that extra 10 lbs.
Hmmm this is a problem. So the first thing I would do is replace your shooter's "runway" with two strips of metal. That will take out a very large amount of weight. That huge piece of plywood has to weigh at least 4 pounds so I would go to a hardware store (Menards or Lowes should have it) and get a piece of 1/8 inch polycarbonate to replace it) Another step is to remove any unnecessary cross-braces. You should also open up unused holes (and add new ones) in the KOP frame members all over your robot (you have a lot of those pieces and they're pretty heavy). Try to eliminate some fasteners (they add a large amount weight) if you have access to a welder then I would recommend welding parts that you don't need to disassemble, if not then you might try rivets. Also, 80-20 adds a ridiculous amount of weight so if you have any (I can't really tell from the picture) I would try replacing it with angle or something. Once again, I would drill LOTS and LOTS of holes, every little bit helps. If you do all of this and it's still not enough, take two drive motors off (if you have four). If worse comes to worse then you'll have to take a mechanism off .
