Go to Post I don't care if students, engineers, my aging grandmother, or a pack of monkeys builds the robot...as long as at least one student walks away inspired then the goal of FIRST has been reached. - Andy Grady [more]
Unread 18-02-2013, 16:59
Robby Unruh's Avatar
Robby Unruh Robby Unruh is offline
*insert random dial-up tone here*
FRC #3266 (Robots R Us)
Team Role: Coach
Rookie Year: 2010
Robby Unruh will become famous soon enough
Radio Lag / Randomly Dropping Communications
Hi,
Our team is noticing a huge packet loss using the legal radio on our competition robot. On our practice robot (using last years radio) there are zero connection-related problems.
We are experiencing a huge amount of packet loss. Up to 25 packets per second over a 20 second time period, after which it will cool down and function normally. After a couple seconds the problems return, and we begin losing packets/comms again. What could cause something like this to happen?
Thanks in advance.
[Robots R Us #3266]
2015: Georgia Southern Classic (Winners / Thanks 1319 & 1648!), Queen City
2014: Crossroads, Queen City
2013: Buckeye, Queen City, Crossroads
2012: Buckeye, Queen City
2011: Buckeye
2010: Buckeye
Unread 18-02-2013, 17:03
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Radio Lag / Randomly Dropping Communications
Might be conflict for the wireless channel that the DLink defaulted to.
You can try setting different channels in the DLink.
If you have a tool like Inssider, you can see what conflicts there are in the area.
Unread 18-02-2013, 17:20
Team Role: Coach
Rookie Year: 2010
If you have a tool like Insider, you can see what conflicts there are in the area.
We installed InSSIDer and took a look... nothing seems to be interfering.
To elaborate a little more, "Watchdog Not Fed" flashes occasionally when it lags out (not every time). Sometimes the Robot Code blip will turn off, sometimes the Communications will turn off, sometimes both will. It appears totally random. I'm not sure if this has anything to do with the root of the problem, but I thought I should mention it.
[Robots R Us #3266]
2011: Buckeye
2010: Buckeye
Unread 18-02-2013, 17:28
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Rookie Year: 2012
rich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond repute
In practice at our school, we did not notice any problems.
We were at a practice site yesterday, and they had problems with the Field Management System, so all the teams switched to wifi direct connect. Most of the teams were experiencing the same problems you mentioned. At first, I thought everyone was saturating the wifi, but the problems persisted when:
1) There were only two bots on the field; and
2) The bot was at the loading station less than 5 feet away from the driver's station.
This evening I will be checking the bot back at our school.
Unread 18-02-2013, 17:29
Jefferson Jefferson is offline
AKA: Jeff Clements
FRC #0016 (Bomb Squad)
Rookie Year: 2010
Jefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant future
Originally Posted by Robby Unruh View Post
Sometimes the Robot Code blip will turn off...
We have seen this more times than I'd like. We haven't been able to find the route cause yet. It seems to get worse the longer the crio goes without a reboot. If it sits long enough the Robot Code drops out for good.
Unread 18-02-2013, 17:41
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
I wonder if it has something to do with the QOS settings that were added to the router configuration this year. Do you have a camera on the robot? Try disabling the video on your Dashboard and see if that helps.
Unread 18-02-2013, 17:52
Rookie Year: 2012
That was the last thing we tried at the practice yesterday. We asked all the teams to disable the live feeds to see if that helped the communication problems. No change.
I am hoping that the FMS prioritization of packets helps, but given the same problem with close communications (less than 5 feet) and when there were only two bots, I don't think it was a saturation issue.
Unread 18-02-2013, 18:41
Team Role: Coach
Rookie Year: 2010
It looks like this was it. We disabled QOS management on our router and it appears to be working fine.
[Robots R Us #3266]
2011: Buckeye
2010: Buckeye
Unread 18-02-2013, 20:03
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
What were the video settings that you were sending?
Unread 19-02-2013, 01:17
4057programmer 4057programmer is offline
FRC #4057
4057programmer is an unknown quantity at this point
I don't honestly have a good answer to the question, but I felt it was worth mentioning that My team has had the exact same problems as well. Meaning this isn't an isolated incident. Could it be the new router configuring software that was given to us this year? Last year's bridge worked just fine and I configured that manually. This year I used the software and I am having issues. Or am I completely off?
Team 4057: Autodesk regional Rookie All-stars!
If it's not on fire, its programming. If it compiles, it's electrical
