Go to Post Let the team grow, let them fail, let them learn and always be ready to lend a helping hand. I think that's the best way to help rookie teams. - Justin Montois [more]
Unread 18-02-2013, 18:18
will478's Avatar
Happy Birthday! will478 will478 is offline
AKA: Will Goettl
FRC #2989 (Holy Spartans)
Rookie Year: 2013
will478 is an unknown quantity at this point
D-Link
How do you connect the D-Link router to the robot? Thanks- Team 2989
Unread 18-02-2013, 20:11
plnyyanks's Avatar
plnyyanks plnyyanks is offline
Data wins arguments.
AKA: Phil Lopreiato
FRC #1124 (The ÜberBots), FRC #2900 (The Mighty Penguins)
Rookie Year: 2010
plnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond repute
Re: D-Link
Use a CAT5 ethernet cable (one came in the Kit of Parts) and plug one end into the dlink and the other into your cRIO. If you have an 8 slot cRIO, plug it into ethernet port one. Take a look at this document, specifically starting on page 10.
Phil Lopreiato - "It's a hardware problem"
Team 1124 (2010 - 2013), Team 1418 (2014), Team 2900 (2016)
FRC Notebook The Blue Alliance for Android
Unread 18-02-2013, 21:23
DonRotolo's Avatar
Back to humble
FRC #0832
Re: D-Link
Also be advised that there is a very specific, and absolutely mandatory, way of connecting power to the DLink radio. Please search the rules for it, but if you cannot find it, feel free to ask again here. If you don't do it correctly, you will fail inspection.
Unread 18-02-2013, 22:34
linuxboy linuxboy is offline
AKA: Oliver Graff
FRC #3780
linuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud of
Re: D-Link
I'd like to amend what Don said. If you don't connect it correctly you _should_ fail inspection, however don't use that as a failsafe of "oh, well if it's wrong inspection will catch it and tell us how to fix it". Many teams have competed with improperly wired D-Link radios. The reason there is a specific way to wire the D-Link is because if it is wired improperly it could turn off during a match and take (on the Rev. A) 50 seconds to turn back on.
tl;dr Be sure to look at the wiring rules so you don't disconnect for 50 seconds of a match.
