Go to Post Let's leave the football uniforms at home though, teams. ... The last thing I want to see is Baker in Brett Favre yellow spandex... *shudder* - Amanda Morrison [more]
Unread 02-18-2013, 09:35 PM
Baldwin Robotic's Avatar
Baldwin Robotic Baldwin Robotic is offline
FRC #2439
Baldwin Robotic is an unknown quantity at this point
Solenoid problems
hi,
our team has almost a day left before we put the robot in a box and ship it out so please answer quick.
we have programmed and wired correctly the 2 double solenoids that we are using, the lights changed from side to side (like their suppose to), and the the pneumatic pistons have pressure in them. But when we push the buttons to go down and up the pistons do not change.
please help
thanx
Unread 02-18-2013, 09:40 PM
Garten Haeska's Avatar
Garten Haeska Garten Haeska is offline
AKA: Garty
FRC #2861 (Infinity's End)
Garten Haeska has a spectacular aura aboutGarten Haeska has a spectacular aura about
Re: Solenoid problems
Do the lights on the solenoid breakout board (on the cRio) change along with the ones of the valves?
"Sometimes the questions are
complicated but the answers are simple."
- Dr. Seuss
Unread 02-18-2013, 09:48 PM
FRC #2439
yes, they do change at the same time the valves do.
Unread 02-18-2013, 09:57 PM
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
  1. Are the solenoid coils marked as 12v or 24v?
  2. What voltage do you have wired into the Solenoid Breakout - 12v or 24v?
  3. Is the power status light on the Solenoid Breakout bright green?
  4. Does the Solenoid Breakout have 2-pin ports or 3-pin ports?
  5. Are the red wires connected from the solenoid to the outside pin on the Solenoid Breakout, and the black wire connected to the inside pin of the connection?
Unread 02-18-2013, 10:04 PM
FRC #2439
1. they are 24v
2. they are wired 24v
3. yes it is bright green
4. it is two pin ports
5. and yes they are red out side and black inside
Unread 02-18-2013, 10:09 PM
FRC #2439
the solenoid break out is actually 12vs... ops found the problem but how do we fix that?
Unread 02-18-2013, 10:24 PM
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Someone else just asked that earlier today--use the open slots in the 24V port the cRIO connects to. I believe they're C and NC, can't quite remember which wire goes to which.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 02-18-2013, 11:38 PM
Kevin Sevcik's Avatar
Kevin Sevcik Kevin Sevcik is online now
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
The PDB datasheet suggests the terminals go +-+-. Best bet is to check with a voltmeter, though.
Unread 02-19-2013, 09:41 PM
FRC #2439
Thank you for all your help!
Now it is time to put the robot in the box!
Unread 02-19-2013, 09:54 PM
Just Itinerant
What do you mean?
We have two whole hours left.
Enough time for a redesign...
