Our first climb and dump of the season!
We have a little work to do tomorrow before we're done, but things are looking good so far! Still to do:
- Fine tune some PID constants/arm movements - Use a battery that hasn't spent the past 2 hours trying to climb - Fix a limit switch triggering issue - Add a support brace for the dumper shaft (it's flexing quite a bit right now, causing the chain to jump) - Add a second motor to the winch mechanism (oddly enough, the electrical team assumed 2 motors to start with, so the Talon and wiring is already in place. We just need to hook it up, plug it in, and drop in the breaker!) - Remove some pauses we added so we could make sure everything was working properly, and have time to stop it if it wasn't. http://www.youtube.com/watch?v=rG-0zyK8FoE Last edited by Jon Stratis : 19-02-2013 at 00:10. |
Re: Our first climb and dump of the season!
Now that you've all clicked the link above, here's the real one
![]() http://www.youtube.com/watch?v=VIjAOGilqII |
Amazing work! |
Fantastic! I believe that's the first video of the full unassisted sequence posted. Looks really great and quite fast. I think you can probably get it under 30 seconds with practice.
Are you worried about making sure you're aligned correctly with the center of the rungs to start? The second video was great, but I'm still laughing from the first! |
Awesome job Robettes! This is going to be an amazing robot to watch out for.
Oh, and two more notes... with the exceptions of a safety trigger (if we release, all motion immediately stops) and a manual button for the dumper, the entire sequence (once lined up) is completely automated. Also, the dumper should be able to dump into the low goal, but we haven't built one as it wasn't a priority. Maybe we'll check that out in Duluth ![]() Last edited by Jon Stratis : 19-02-2013 at 00:28. |
If you're really lucky, you might be able to get that battery back into effective status, if you put it onto a charger very soon after taking it out of the robot. The climb looks very impressive, but it may have demoted that battery to practice only status. I have a great deal of trouble convincing my own team that their energy source is not disposable like AA batteries, particularly when they're having "FUN".
We'll be happy with 30 seconds from floor to 50 points, but we're hoping for 20 We're going to double the power we have on the winch (we had 1 Mini-CIM, we're adding a second), which should help as well... we were really taxing the Mini-CIM to climb that high, and after 2 hours straight of climbing it was hot enough to fry an egg! |
#10
Honestly, I don't know what the team plans. We'll be able to dump in the low goal (just back in and dump it over the arm with the same motion you saw in the video), so we could score a few points that way. Personally, I think the best bet is to get our 4 colored discs and try to disrupt the flow of scoring for the opposite alliance until we need to climb. We're too low to block most shooters, but we can do some pushing, and prevent/delay robots from traversing the field (assuming they can't shoot full court).
#13
This is how side climbing should be done. Our major concern with side climbing was that the swinging would make climbing extremely slow. It's clear that you've found a great way to minimise swinging. While this isn't mind blowingly fast, it's obviously quite quick. You should do very well this season.
#14
Way to go, Robettes!
Andy Baker |
#15
Congrats to you and your team Jon! I can't wait to see it in person.
