Go to Post I was on the same plane as 365 returning from Atlanta to Philadelphia last year. The whole rear half of the plane was neon green. - Lil' Lavery [more]
Unread 19-02-2013, 11:43
Alchemy99's Avatar
Alchemy99 Alchemy99 is offline
AKA: Josh Cote
FRC #3141 (Team Alchemy)
Team Role: Leadership
Rookie Year: 2007
Alchemy99 is an unknown quantity at this point
Send a message via AIM to Alchemy99 Send a message via Yahoo to Alchemy99
Dashboard Problems.
Ok so something went wrong with our dashboard. when we load up the driver station. the driver station loads correctly but the dashboard its self can't find files. an example of that is "LVODE.dll" and when i manually find all the files it is loading a different dashboard than the one in /program files/FRC Dashboard. (dont remember the exact address)
my question is where do we have to put the dashboard.exe? (custom one made in lab view based on the project.)
Sorry if this was already covered, i couldn't find it. (im not that good at searching either)
Unread 19-02-2013, 11:52
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Dashboard Problems.
Check on the Driver Station Setup tab to see if Default Dashboard is selected
If LabVIEW is selected then the Driver station will look for a project in the standard location with the same name as the original LabVIEW Dashboard project. The same with any of the other dashboard types - Java or C++
If you choose Default on the Setup tab, then you can replace the default dashboard with your own at:
C:\\Program Files (x86)\FRC Dashboard\Dashboard.exe
Unread 19-02-2013, 11:55
Alchemy99's Avatar
AKA: Josh Cote
Rookie Year: 2007
Thank you, That should solve our issues.
We selected LABVIEW as the dashboard type, (because we are using labview.) but we have 2 different dashboard projects, and it was loading the old one.
Thank you again.
Unread 19-02-2013, 12:50
Omar's Avatar
Omar Omar is offline
Omar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of light
The Driver Station looks for the LabVIEW Dashboard.exe that you created at
My Documents\LabVIEW Data\builds\FRC Dashboard Project\FRC PC Dashboard
When you select the "LabVIEW" Dashboard from the Driver Station Setup tab.
The default "Destination directory" should point to this directory in the Dashboard "Build Properties"
Omar
