Go to Post Right now, it drives around....hopefully tomorrow it will do a LOT more! - MrForbes [more]
Unread 19-02-2013, 14:42
Crzycoco Crzycoco is offline
Co-Capt.
Rookie Year: 1234
Crzycoco is an unknown quantity at this point
Smile How to call out these buttons?
Hi I was wondering how to call out these buttons on NI LabVIEW? Thanks
http://imageshack.us/photo/my-images/28/button1qb.png/
http://imageshack.us/photo/my-images/138/2buttons.png/
Unread 19-02-2013, 15:13
Omar's Avatar
Omar Omar is offline
Omar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of light
Re: How to call out these buttons?
Search for "Unbundle By Name"
Name:	Unbundle By Name.png
Beyond that what do you mean by "call out"
Omar
Unread 19-02-2013, 15:20
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Those are Unbundle By Name functions. You'll find them in the Cluster, Class, & Variant function palette. You wire a cluster to the input, and you select which member of the cluster to output (the name can be clicked on to show a menu). They expand at top and bottom (drag the edge) to give you more individual outputs to select from.
Unread 19-02-2013, 15:22
Omar's Avatar
By search, you can use the "Quick Drop" to find it.
Press 'Ctrl-Space Bar'
Start typing 'unbundle ...
You should then be able to select "Unbundle By Name"
Omar
