Go to Post bump. - connor.worley [more]
Unread 02-19-2013, 08:42 PM
Gmercer Gmercer is offline
None #1631
Gmercer is an unknown quantity at this point
How do i initialize the GearTooth sensor
I just received a GearTooth sensor today to program into the robot in order to keep track of RPM, but i have no clue how to set up the gearTooth. I read the documentation on the class but couldn't figure out what to do, here is what i currently have:
Declaration:
Code:
GearTooth shootSensor = new GearTooth(3);
in the robot initialize function:
Code:
shootSensor.setupSource(3);
my data function(called every two seconds in the main loop):
Code:
SmartDashboard.putNumber("Test:",shootSensor.getPeriod());
no values though, what could i be doing wrong?
Unread 02-19-2013, 09:04 PM
BradAMiller BradAMiller is offline
AKA: Brad
#0190 ( Gompei and the Herd)
BradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant future
Re: How do i initialize the GearTooth sensor
Try replacing the setupSource() method with start(). This will start the GearToothSensor listening on port 3 for the counts.
You don't need to set up the port since you are passing the channel number (3 in your case) to the constructor. The GearToothSensor object will allocate a the port for you.
Brad
Brad Miller
Robotics Resource Center
Worcester Polytechnic Institute
