Go to Post We are engineers after all so I say "Bring on the technology"!:yikes: - emersont49 [more]
Unread 20-02-2013, 00:29
nickcvet89 nickcvet89 is offline
FRC #1228 (RoboTribe)
nickcvet89 will become famous soon enough
Send a message via AIM to nickcvet89
Getting Error Message on DS
Hey everyone, we are getting error messages on our DS when we are driving and shooting. At times, if we drive or run the robot too hard, the robot just stops and all functions cease to work and we get red lights under communication and robot code, after about 5-10 secs, robot kicks back on and teleop is still running as nothing happened. I attached a photo of some of our errors. We also get a watchdog error at the end. We are currently using the 4-slot cRIO and the new 2013 router. Thanks for any help.
Unread 20-02-2013, 00:31
remulasce remulasce is offline
Rookie Year: 2007
remulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to behold
Re: Getting Error Message on DS
Look at the voltage on the dashboard, and see if it fails under a certain voltage, or with an old battery.
Also, make sure you're using the specified voltage regulator to power your radio- you can't just plug it in to the PD board.
Student 294: 2007-2011
Mentor 597: 2013-2015
Google SWE: 2015-
Unread 20-02-2013, 00:33
Blackphantom91's Avatar
Blackphantom91 Blackphantom91 is offline
Mentor + 4 = Stuck For Life
AKA: Malcolm Stirckland
FRC #1986 (Team Titanium)
Blackphantom91 has a spectacular aura aboutBlackphantom91 has a spectacular aura aboutBlackphantom91 has a spectacular aura about
Are you sure that those are all of the errors the easiest way to look at all of them is to ctrl-A then paste into a notepad doc.
[img*]http://i.imgur.com/Os2oTET.jpg[/img*]
Unread 20-02-2013, 07:50
My guess is that the robot is connected to the laptop using an ethernet cable and the DLink rebooted due to a voltage sag. The Charts tab of the DS will help indicate whether the voltage was getting low, and that bottom message is from the cRIO saying that the radio disappeared and reappeared two times that many seconds ago. The DS Log File viewer will process those raw messages and hopefully show them in a clearer way.
The solution is to trace the power wires of the DLink back to the PD and compare that to how the manual and inspection guide require you to do it.
Greg McKaskle
Unread 20-02-2013, 19:56
We get these messages when we're wireless.
Unread 20-02-2013, 21:13
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
A communication dropout of "5-10 secs" is difficult to explain. Do you perhaps have your D-Link router mounted too close to metal or too near a speed controller?
Unread 21-02-2013, 07:31
I was guessing wired, because the switch capability of the DLink comes up pretty quick, like in three seconds. Powering up the wireless takes much longer. Can you wiggle the ethernet cable between the DLink and the cRIO and see if you can cause the situation? Also do the bend and flex of the cable to see if it has been nicked or has an internal break.
You may also consider replacing the cable and repeating the previous test.
The message basically says that the DS lost connection to the robot. That happens each time you power down the robot, for instance. So things that cause the communication to drop out for 5-10 seconds are what you are looking for.
Greg McKaskle
