Go to Post It's the corollary that you pick them no matter what shape they start the event in. Pink is known for showing up at their 1st regional with the robot in an unfinished state. And somehow, magically by the end of qualifications it just works, and they win. - Nuttyman54 [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 24-06-2002, 00:11
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
archiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond repute
Out of bounds... -- copy of posting in General
Posted by Joe Johnson.   [PICTURE: SAME | NEW | HELP]
Engineer on team #47, Chief Delphi, from Pontiac Central High School and Delphi Automotive Systems.
Posted on 10/20/2000 1:18 PM MST
: Question:
: If your team picks up the rack and 'carries' it to your teams side and you happen to swing the rack out of bounds (but you are still holding onto it and you are in bounds) will you be disqualified?
: Answer:
: Disqualification is not even an issue in this situation. Disabling is a possibility but not Disqualification.
: Now to the specifics. If your robot applies force to the ground outside the field, your robot is subject to being disabled. If it applies that force via a ball or its arm or the square rack it is all the same with respect to this rule.
: If the square rack is touching the ground outside the field at the end of the match, it will not count as a doubler.
: Clear?
: Joe J.
This message was archived from an earlier forum system. Some information may have been left out. Start new discussion in the current forums, and refer back to these threads when necessary.
[IMG] code is Off
Casters -- Copy of Post in General archiver 2000 0 24-06-2002 00:11
'Aluminum Angle/box/tube'-- copy of posting in General archiver 2000 0 24-06-2002 00:11
Scoring Clarification -- copy of posting in General archiver 2000 4 24-06-2002 00:11
Why don't people start posting? Ken Leung General Forum 22 01-12-2001 01:27
