Go to Post We have about 16 pounds more to add, including the code- all that code can get heavy! - Dave Campbell [more]
Thread Tools Rating: Thread Rating: 44 votes, 5.00 average. Display Modes
Unread 20-02-2013, 12:58
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
Rookie Year: 2012
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Running multiple PID loops on the drivetrain
Is it possible to use more than one PID controller for a subsystem like the drivetrain? Example: An encoder PID loop to drive to a distance setpoint, while a gyro PID loop keeps the robot going straight.
You could also substitute encoder with Ultrasonic sensor, etc.
If you can't run them simultaneously, is there a way to switch between PID controllers to, say, drive forward 5 meters distance (via encoder), then turn 90 degrees (via gyro), then drive forward again, etc?
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
