Go to Post Last year we saved a ton of money by using a good bit of square tubing for the frame of our robot, square tubing is a lot cheaper then C channel. We get to use so much raw material that the cost should go down in certain places. - Derrick Maust [more]
Unread 20-02-2013, 15:04
BigDaddyKane527's Avatar
BigDaddyKane527 BigDaddyKane527 is offline
YEAH WOO! WOO YEAH!
AKA: Rob Kane
FRC #0527 (Red Dragons)
BigDaddyKane527 is an unknown quantity at this point
Smile Error 44061
Hello everyone! Sorry if this is in the wrong spot but I'm new to this.
Our code has been having issues with CPU usage. This happens in autonomous and in teleop. Suggestions for why this is happening would be greatly appreciated. Thank you!
Unread 20-02-2013, 15:09
billbo911's Avatar
billbo911 billbo911 is offline
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
Re: Error 44061
We ran into this last night. Follow the instructions in the link below.
http://www.chiefdelphi.com/forums/sh...ighlight=44061
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 20-02-2013, 15:12
Re: Error 44061
This message indicates that the loop that was calling RobotDrive isn't updating the output values as often as it said it would. The default is 100ms.
The most common reason for this is that your teleop function is calling RobotDrive and you have code that is sequencing through operations with relays or solenoids with delays in between, and this causes your teleop to miss the deadline.
Another reason is that the RobotDrive is placed into a case structure and it isn't being called to refresh the timer.
Do either of these sound likely?
Greg McKaskle
