Re: pic: Team 1592 Ultimate Ascent robot, Buzz.
The gas springs make the load on the system pretty well near zero unless accelerating. Aka the system thinks its close to weightless while sitting still. There is still inertia that has to be overcome but the shooter assembly as a whole is pretty well balanced. Before the lead screw was put on it would hold what ever position you pushed it to. So in short they allow us to have to go through less of a reduction in order to change the angle of the shooter which allows us to do it more rapidly.
This sounds kind of inefficient, if I understand correctly. Getting your arm "weightless" is a great idea! Well done! |
On the back of the robot is a chamber that rotates between feeding the shooter as shown in the picture and straight out.
When it is straight out the back, it serves 2 purposes. It serves as a method for the HP to load frisbees into the robot, and it allows one of our stowed frisbees to be loaded in the chamber and then rotated to be fed into the shooter. I'll find a picture that can better illustrate the process. Chris |
Thanks, sorry for being so dense
Nah its ok. I can see how what I said could have been mistakenly read.
