Go to Post We're all human, we all make mistakes. How you deal with mistakes and problems, is what really elevates successful people, robotics teams, organizations, etc. above the rest. - artdutra04 [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 24-06-2002, 00:13
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
archiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond repute
scoring ramp dimensions
Posted by Suzy.
Engineer on team Bulldogs from Breithaupt/Renaissance sponsored by DaimlerChrysler.
Posted on 10/22/2000 6:05 PM MST
Do you have the dimensions of the scoring ramp? I mean the placement of the squares on the ramp, where are they compared to the sides and each other?
This message was archived from an earlier forum system. Some information may have been left out. Start new discussion in the current forums, and refer back to these threads when necessary.
#0047 (ChiefDelphi)
See Field Section
Posted by Joe Johnson.   [PICTURE: SAME | NEW | HELP]
Engineer on team #47, Chief Delphi, from Pontiac Central High School and Delphi Automotive Systems.
Posted on 10/22/2000 6:41 PM MST
In Reply to: scoring ramp dimensions posted by Suzy on 10/22/2000 6:05 PM MST:
See the picture below.
It has been up for days on the 'field pictures' section of the main CDI page.
Good Luck.
Joe J.
#0047 (ChiefDelphi)
Re: See Field Section
Posted by Suzy.
Posted on 10/23/2000 5:26 PM MST
In Reply to: See Field Section posted by Joe Johnson on 10/22/2000 6:41 PM MST:
the picture is blurry and hard to read, this is why I asked for dimensions. Please list what the numbers are supposed to be or have a sharper picture. thanks from a 'blind' engineer.
#0047 (ChiefDelphi)
What my eye sees...
Posted on 10/23/2000 6:53 PM MST
In Reply to: Re: See Field Section posted by Suzy on 10/23/2000 5:26 PM MST:
The numbers look okay on my screen. Perhaps it is just that I have seen them before.
In any case here is the basic dim. stuff.
The squares are all 9 1/2 by 9 1/2 so I won't go into them any more.
Skipping the dim's detailing the squares, the dim's on the left side of the ramp read (from top to bottom)
34 3/4
19
3 1/4
Again skipping the dim's for the squares, the dim's along the top of the ramp read (from left to right)
9 1/4 and 29 1/4
The entire ramp is 48 by 48 in true view.
The ramp is 6 inches high (less the carpet).
The sub-floor is a 3/4 inch piece of plywood, spaced down 3/4 of an inch (by a wood '1 by 3'). The sub-floor is carpeted in the color of the ramp (red or blue, depending on the side of the field).
The edges and middle support for the ramp are made from a '2 by 6' cut into right triangles, the legs of which are 5 1/4 and 47 11/16. (Which works out to be 47.975 inches for the long side of the triangle -- ideal for mounting a 48 X 48 inch sheet of plywood to ;-)
I hope that this clears things up a bit.
Joe J.
[IMG] code is Off
Robot/Goal scoring: Official Answer Mike Martus Mike Martus OCCRA 6 21-10-2003 23:51
Pulling robot off ramp legal? archiver 2000 2 24-06-2002 00:14
hieght of the scoring ramp archiver 2000 1 24-06-2002 00:08
Technical question about ramp balancing archiver 2001 5 23-06-2002 22:29
Field and shelf missing dimensions kmcclary Off-Season Events 3 12-10-2001 18:21
