Re: Team Driven 1730 Reveal
Great looking robot! Can't wait to see you guys up at Fayetville should be a lot of fun!
The exact gearing that this occurs at is dependent on the actual coefficient of friction of your wheels, the motors you're using in the gearboxes, and the total weight of your robot. This is why most teams that do 2 speed gearboxes run around 5-7 ft/s in low gear and 15-19 ft/s in high gear, giving them one traction-limited gear that will accelerate well and won't stall the motors in a pushing match, and one high-speed gear for getting around the field quickly. The good news is that at 2.3 and 12 ft/s, both of your gears will probably be traction limited, so you're probably not at risk for stalling motors. They're fine speeds for driving around the field and for precise alignment. Just don't be fooled into thinking you get more pushing power out of the low gear. Unless your high gear stalls the motors before the wheels spin, they will both have the same amount of pushing power. |
I think what shocks me the most about your machine this year is the lack of 8020! What caused you guys to move away from that material this year?
Team Driven robots haven't had a lot of 8020 for the last few years (2010 was the last robot with a lot) It's heavy and unnecessary most of the time.
Clint beat me to it. |
Can weight be added to the bumpers as long as you stay under the 20 lbs limit? No, BUMPERS must be constructed as outlined in [R24]. |
I haven't seen the actual bumper construction but using Figure 4-4 (Bumper Cross Section) and the "1 in. limit for hard parts", you can add right at 14.5LBS to a otherwise "normal" set of bumpers simply be using 1"x1"x.125" steel angle iron (.8lbs per linear ft) on both the top and bottom of a full-perimeter set of bumpers.
While this might be considered playing in the grey area of the Question 480 response, it wouldn't seem to be in violation of R24 in any way I can see. Further, by using .1875" or .25" angle iron you could increase your bumper weight even more! |
120 lbs robot + 13 lbs battery + 20 lbs bumper = 153 lbs.
Mike is right about the metal trim. There doesn't seem to be be any specs on what that trim must be, so using it to add or manage your weight should be perfectly legal, as long as your bumper assembly remains under 20 lbs. We considered doing it ourselves, but found a place to put the weight within the robot. I think the Q&A response refers to adding "weight" in the form of some ballast piece that is not part of the legal bumper construction. Last edited by jspatz1 : 26-02-2013 at 21:11. |
#10
Thanks, your guys' looks pretty awesome as well. Hopefully we both can get some practice time with each other. That would be nice so we both get some time with other robots on the field
#11
Sounds good to me.
#13
What made you decide to orient the shooter sideways relative to the drivetrain?
#14
The sideways oriented shooter was inherent in this design. This design came as it's own concept as a whole robot instead of the typical sub-systems due to the nature of this concept.
#15
Also we were thinking of going straight on, but if you think of basketball, the defender moves side to side and the shooter moves side to side to avoid defense. We believed this potential could be a heavy defensive game, we decided to go side to side. Instead of having to back up, and realign, we would just get square with the goal, and if defense does show up we can move side to side to avoid the defense without having to realign with goal. Shooting whenever we have the chance.
