Go to Post And yes. The Super Bowl is on, and I'm replying to a thread on Chief Delphi... - BobbyVanNess [more]
Unread 23-02-2013, 10:58
Mr Roboto Mr Roboto is offline
FRC #3160
Mr Roboto is an unknown quantity at this point
Pneumatic ballon
Would it be legal to allow the exhaust from a pneumatic solenoid to blow up a typical toy balloon? Or due to the fact that it would be connected to the pneumatic system, cause it to be considered a pneumatic device and thus fall under the requirements of R76?
Intended use: The balloon would be slowly inflated as we climb the pyramid then used to push discs out of a hopper when we reach the top thereby eliminating the need for an additional mechanical device or movement.
Unread 23-02-2013, 11:03
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Re: Pneumatic ballon
Definitely a pneumatic device in that case. So it would have to be a pneumatic cylinder that's rated for 125 psi. Which it isn't.
Unread 24-02-2013, 10:02
FRC #3160
Thanks Kevin,
I thought that would be the case, but wanted to get another opinion.
Unread 25-02-2013, 09:08
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
I would agree with Kevin as well. The balloon has to fit the COTS part rated for pressure in R76.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 25-02-2013, 11:12
Retired Starman Retired Starman is offline
FRC #3573 (Ohms)
Retired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud of
Interesting question.
I don't think a balloon would be legal, but another accumulator might be. It would have to have some sort of check valve on it to keep the air in the tank each time the actuator is moved the other way. Further, some sort of valve would be necessary to make sure 60 psi air didn't just bypass the actuator and move into the new accumulator. It might also require a relief valve to make sure you don't store more than 60 psi in the new accumulator.
Dr. Bob
Chairman's Award is not about building the robot. Every team builds a robot.
