Go to Post it's flattering, but a little scary, because I don't know if I'm ready to be an inspiration! - MissInformation [more]
Unread 23-02-2013, 15:36
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Sabre Bytes 772 - 2013 - Present FLASH
Here is 772's 2012 robot "FLASH!"
The team worked hard to make the most Simple and Fastest robot we could.
Our goal was to have a human loading robot that could pick up off the ground for autonomous and end game purposes, we figured out our picker upper was illegal, and will possibly have a new one after FLR.
The shooter is a simple 90 degree shooter with a direct driven 6inch VEXPro traction wheel. The feeding system is a simple bucket with a belt underneath that pulls the Frisbees into the shooter. We have gotten this to shoot 4 Frisbees, accurately, in 0.9 seconds. Keeping with the simplicity we don't even have an angle adjustment, we shoot from the middle of the pyramid mostly, and have other places to shoot from also.
We have a very simple 10 point hang that uses two pneumatic pistons to pull our robot up off the ground. We have the shooter far enough over that we can shoot while hanging in the 2 point goal.
We have two 18 point autonomous, one of which you can see at the end of the video.
And yes there is a reason why the shooter shoots out the side of our robot rather then the front/back. (if I told you please don't post it)
The lights will not be flashing like that during matches.
We will be at Finger Lakes Regional, Waterloo Regional, and Greater Toronto West Regional!
Hope to see you at Champs!!
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 23-02-2013, 16:16
Mongai's Avatar
Mongai Mongai is offline
Indian Guy
AKA: Alec
FRC #0935 (RaileRobotics)
Mongai is just really niceMongai is just really niceMongai is just really niceMongai is just really niceMongai is just really nice
Re: Sabre Bytes 772 - 2013 - Present FLASH
Originally Posted by akoscielski3 View Post
And yes there is a reason why the shooter shoots out he side of our robot rather then the front/back.
Now I'm very intrigued about this design decision Also, slick robot!
Unread 23-02-2013, 16:22
Grim Tuesday's Avatar
Grim Tuesday Grim Tuesday is offline
AKA: Simon Bohn
FRC #0639 (Code Red)
Rookie Year: 2010
Grim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond repute
Maybe just drive by the line of discs in the center and just shoot them right out or something? Maybe it will all be revealed when we see their floor pickup (which might be illegal - I'm curious how a floor pickup can be illegal)
Unread 23-02-2013, 16:24
It was outside of the 54inch Cylinder when it was going down the the floor. design flaw.
and now that's not it
2013-Present
2010-2013
Unread 23-02-2013, 16:26
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
Team Role: Coach
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Maybe the floor loader extends beyond the 54" cylinder?
"A genius is just a talented person who does his homework" T. Edison
Unread 23-02-2013, 16:28
yup!
Did you like my 987 shirt when I was dancing? hahaha
2013-Present
2010-2013
Unread 23-02-2013, 16:47
Andrew Zeller's Avatar
Andrew Zeller Andrew Zeller is offline
Mechanical Engineering at UA
FRC #1716 (Redbird Robotics)
Rookie Year: 2010
Andrew Zeller has a spectacular aura aboutAndrew Zeller has a spectacular aura aboutAndrew Zeller has a spectacular aura about
Very slick design. Love the LEDs. My team has went with simple this year as well. Could you give me some more details about the green belt that you are using to feed frisbees into the shooter (seen in the video at 3:51)? Did you purchase it from McMaster? What about the pulleys driving it? Seems to work very well. Thanks.
Edit: Drivetrain looks like ours as well. Have you experienced wear on the tread of the Versa Wheels? Our center wheel has been wearing faster than the others causing slower turning and I am wondering if once the pointier part of the tread wears off, the larger surface area wears less. Might just have to swap center wheels at competition.
FIRST ROBOTICS TEAM 1716 Redbird Robotics
2012 Wisconsin Regional Judges Award
2012 Wisconsin Regional Quarterfinalists
http://www.frc1716.org/
Unread 23-02-2013, 17:21
We are not using Versa Wheels, we're using Traction wheels with Hatched tread. wheels usually wear over time. Last year the pneumatic wheels 1114 had on their robot were completely flat (tread) and had no tread on them at all, so you may have to change them a few times this year to keep a great drivetrain.
The belt was made for us in 2011 (for our failed gripper) and happened to work for this design. we had a belt made for us this year but it was wide, so if it tracked it would jam. We got it made by a local manufacturer, so no it wasn't from mcmaster-carr.
ahah Thanks Joe
2013-Present
2010-2013
Unread 23-02-2013, 21:33
lorem3k's Avatar
lorem3k lorem3k is offline
1 + 1 = 0 (in Z/2Z)
AKA: Andy D.
FRC #1482 (Bishop Grandin Ghosts)
Rookie Year: 2011
lorem3k is a splendid one to beholdlorem3k is a splendid one to beholdlorem3k is a splendid one to beholdlorem3k is a splendid one to beholdlorem3k is a splendid one to beholdlorem3k is a splendid one to behold
I was sad that we weren't going to see you at any regionals this year, but now that I've seen those LEDs, I'm a little happier about that fact. I like the frisbee advancing mechanism, very ingenious.
Boo! Bishop Grandin High School / GM Canada / Tenaris
2013 Western Canada - Quarterfinalists (thanks 288/4719) / 2012 GTR West - Quarterfinalists (thanks 188/1075) / 2011 GTR East - Regional Winners (thanks 1114/1503)
Unread 24-02-2013, 10:02
When we were practicing a Frisbee fell out of our loading station and landed like this. We already had the face on it fro some reason, the frisbee just made it 10 times better.
2013-Present
2010-2013
Unread 24-02-2013, 11:19
Ekcrbe's Avatar
Ekcrbe Ekcrbe is online now
When can I watch Einstein again?
AKA: Erik Boyle
FRC #4640 (Metallic Panthers)
Rookie Year: 2012
Ekcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond repute
I'm glad to see that we're not the only team shooting out the side. I was getting worried on Premiere Night until I saw 772. Looks slick--definitely more so than ours. Nice work.
Four years of FRC 68 Truck Town Thunder
2012 Championship Newton Division Finalists—Thanks 330 and 639 for the Full Court Press!
2013 Kettering University District Chairman's Award Winners!
2014 Great Lakes Bay Region District Winners—Thanks 288, 4819, and 5166! | 2014 Waterford District Chairman's Award Winners! | 2014 Michigan FRC State Championship Chairman's Award Winners—Congratulations 33 and 503!
2015 Center Line District Chairman's Award Winners! | 2015 Lansing District Winners—Thanks 314 and 1684! | 2015 FIRST in Michigan District Championship Chairman's Award Winners—Congratulations 503 and 2137!
Unread 24-02-2013, 14:08
3929's robot shoots from the side as well, which is what their robot's name comes from: The Stonewall Jackson (has nothing to do with the Confederates lol)
Unread 23-02-2013, 16:50
AKA: Joe Barry
Team Role: Coach
yup!
Of course! My apology, I was so focused on examining your cool bot that I stopped watching the video when the credit frames ran. Goes to show, one must see everything to see everything...
