Go to Post I then asked if I could use a flux capacitor for power, but that didn't go over too well, either (they did say I could use it for decorative purposes, though). - Kevin Watson [more]
Unread 25-02-2013, 12:58
Shu Shu is offline
FRC #2137 (TORC)
Shu is an unknown quantity at this point
Re: Balancing a Pneumatic wheel
Originally Posted by Al Skierkiewicz View Post
OK, time to add a few words of sense to this discussion.
1. Adhesives, particularly double sticky tape are not fasteners. We can argue industrial adhesives but so far I have not seen anyone discuss these yet.
2. The tread of the pneumatic tires you are discussing cannot take the force of the wheel speeds that will be generally encountered. I believe the operative phrase is "destructive disintegration". Have you noticed how hard it is to find any speed data on these tires?
3. The imbalance and vibration is telling you something, you are not listening.
4. Just because you haven't witnessed parts leaving the flywheel yet, doesn't mean it won't happen.
5. Most of you are using motors that free speed above 15,000 RPM. Coupled to a 3:1 transmission, what numbers do you get? Direct drive on a 775 is over 7,000.
I think you guys need to rethink your designs to be sure. Not pretty sure, not 'oh it will never happen' sure, really sure. Please remember that inspectors will be looking at your robot with this in mind...
R08
ROBOT parts shall not be made from hazardous materials, be unsafe, cause an unsafe condition, or interfere with the operation of other ROBOTS.
I am sure that if your design should cause any flying debris, an inspector will be asked to either disable your mechanism until such time as you can prove it won't hurt anyone or anything, or whatever it takes to prevent a re-occurrence. Now is the time to be really sure, not during competition.
Hi Al,
There are many teams using these pneumatic tires on their shooter but I am getting the impression from your various posts that you are deeming them unsafe to use in this application. My concern is that you as a inspector or someone else will rule them illegal during inspection based on what you specified. This will in turn render a robot's shooter useless until another "more safe" wheel is used.
Yes, these tires were not specifically designed to be used under these circumstances but I have yet to hear of one coming apart. I agree that great care needs to be taken in how they are mounted and balanced. Also, it is highly recommended some sort of shield be used to prevent any flying debris should something come loose.
If a team takes these steps, do you see them capable of being used in a safe manner?
Unread 24-02-2013, 11:29
Justin Shelley's Avatar
Justin Shelley Justin Shelley is offline
FRC #3885 (Shockers)
Team Role: Driver
Rookie Year: 2012
Justin Shelley is on a distinguished road
Send a message via MSN to Justin Shelley
Originally Posted by Andrew Schreiber View Post
Remind me to wear my kevlar vest to any event you're at.
Seriously, don't forget to take into account that these wheels are running at speeds they were NOT designed for. Make sure anything you attach to them can handle the speeds.
I think if the weights will work on sport bikes that they will be fine on a robot wheel a 2006 yzf r6 has a top engine rpm of around 21,000RPM. The sixth gear reduction ratio is 1.074. Dividing 21,000RPM/1.074 will produce the RPM of the rear wheel. This comes out to be 19,553RPM. I don't think the shooter wheel is hitting that speed lol Now i realize you may do the math and realize nobody ever drives that fast but when the bike is doing 250MPH, people do drive that fast on the track, the rear wheel is spinning at abut 3,703RPM which is faster then any shooter wheel is spinning. So Andrew you are just fine using wheel weights
Unread 24-02-2013, 11:52
Andrew Schreiber Andrew Schreiber is offline
Data Nerd
FRC #0079
Rookie Year: 2000
Andrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond repute
3703 < 5000 So I'm not seeing your point. I know one of my wheels is geared close to 7500 rpm. Now, I'm aware I'm not hitting that speed but I'd be willing to bet you that it's well above 3700rpm. And frankly, I don't care if it "should" be safe. I care that it is. I care that teams took some time to put in safe guards to prevent shrapnel hitting people because I'm selfish and I enjoy the use of all of my limbs.
Unread 24-02-2013, 11:55
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
That's well over 1200 miles per hour. I don't think the wheel itself would survive, much less stick-on weights.
Based on reports I've seen here, some frisbee shooters are spinning their wheels at 6000 RPM or higher. 5000 RPM seems common. Whether or not you use wheel weights, if you're running a wheel at several thousand RPM, you'd better have an effective containment system to protect the outside world in case something spontaneously disassembles itself.
Unread 24-02-2013, 14:59
Team Role: Driver
Rookie Year: 2012
I believe those are the smaller wheels, not the pneumatic. If someone is spinning that pneumatic wheel over 4,000 RPM then the are lucky they still have a wheel.
