Go to Post The "line" is the point at which we've raised the floor so high that the advanced teams are hitting the ceiling. The ceiling is pretty darned high (and the GDC keeps raising it), so I don't think we're in danger of that any time soon. - EricVanWyk [more]
Unread 02-24-2013, 03:30 PM
Mr.Roboto3335's Avatar
Mr.Roboto3335 Mr.Roboto3335 is offline
Wait, What?
AKA: Jimmy
FRC #3335 (Cy-Borgs)
Rookie Year: 2011
Mr.Roboto3335 is an unknown quantity at this point
Programming Limit Switch
I have no idea how to program a limit switch. If anyone could give me an example or link on how to program one it would be appreciated.
Wait, what?
Unread 02-24-2013, 04:56 PM
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
Rookie Year: 2012
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Re: Programming Limit Switch
What are you doing with it?
Here's the basic code:
Code:
DigitalInput limitSwitch;
    public RandomSubsystem() {
        limitSwitch = new DigitalInput(1);     //1 = the DIO port of the sensor
   public boolean getLimitSwitch() {
        return limitSwitch.get();
   public void doSomething() {
        if(getLimitSwitch() == false) {
             doSomething();
Then call doSomething() from a command and set the isFinished() method to trigger when getLimitSwitch() returns true.
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 02-24-2013, 06:26 PM
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
FWIW, if you plug it directly into a Jag you don't need to program it.
