Go to Post Is CAD essential to all teams? No, but neither are power tools. - 346CADmen [more]
Unread 26-02-2013, 22:44
ttldomination's Avatar
ttldomination ttldomination is offline
Sunny
Rookie Year: 2007
ttldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond repute
Buggy BAG Motors
Hello Everyone,
We're running one of our BAG motors at about 80% power into a 1:1 VEX VersaPlanetary.
Earlier today, it appeared that we had a BAG motor give out on us. We can't tell if it's a loose connection in the motor's internals, or running the system with 1:1 wasn't the wisest idea (with 2, 3-7/8 blue banebot wheels).
Anyone experience any sort of performance issue with a similar setup? We're wondering if we need to perhaps reconsider our setup or perhaps it was a one-time occurrence.
- Sunny G.
1648: 2013-2014
5283: 2015
Unread 26-02-2013, 22:54
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: Buggy BAG Motors
We had one get a bit flaky on us. Low torque, and if it stopped in a certain place it wouldn't start again, but if it ran continuously it would keep on running. Took it apart (very nicely made motor inside) and it seemed like the brushes may have been hanging up a little bit, took them out, put them back in, slid them back and forth a little bit, and it seems fine.
Unread 26-02-2013, 23:01
JJackson's Avatar
JJackson JJackson is offline
FRC #0781 (Kinetic Knights)
Team Role: Driver
JJackson is an unknown quantity at this point
We had an issue with a couple. We found that the coating on two of the wires going to the commutators wasn't stripped off before they were soldered together. We stripped off the coating and re-soldered the wires to the commutators and all was well.
Hope this helps
We didn't think about making a deal of it as we didn't find anyone else with the issue
Unread 26-02-2013, 22:56
zbutner zbutner is offline
AKA: Zachary Butner
FRC #2415 (Wiredcats)
Team Role: Student
zbutner is an unknown quantity at this point
BAGs are giving out on us too. In a 30:1 VersaPlanetary gearbox. We found that we could change rpms by moving around the leads. The motor would stop running for a short time then turn on again. We're switching to an RS550.
Unread 26-02-2013, 23:04
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
We had the exact same symptoms, except in the 1:1 configuration. The max rpm would sometimes be different, and we tried adjusting victors, when finally the motor just wouldn't move when we applied power. Looks like we're packing some RS 545's before the team leaves for Palmetto tomorrow.
I'll see what I find when i take one apart. Has anyone else been experiencing similar symptoms?
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 26-02-2013, 23:09
SM987 SM987 is offline
AKA: Stephen McKinney
FRC #0987 (The High Rollers)
Team Role: Teacher
SM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond repute
987 has had similar issues to what you are all describing on 3 of our BAG motors. VEX support has been extremely helpful via phone and email support and we are sending these back. Agree with sanddrag that the internals are high quality. We had the issues when attached to planetary gearboxes and under no-load situations.
Attending:
2017 Utah Regional
2017 Las Vegas Regional
2017 FIRST Championship Houston
Team 987 - The Highrollers - Las Vegas, Nevada
Unread 26-02-2013, 23:16
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
FRC #2410 (BV CAPS Metal Mustang Robotics)
Rookie Year: 2010
CalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond repute
We haven't had any particular problems we weren't able to solve. As well as what's stated above, make sure that the set screw clamping the gearbox and motor is tight (and hopefully still there!). Tightening (or replacing) them has solved our issues.
Team 2410 thinks KISSing is amazing! Keep It Super Safe!
  • "You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
  • Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together - nothing works and nobody knows why.
MMR 2410 Student (2010 - 2013) | MMR 2410 Mentor (2013 - Present)
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 27-02-2013, 00:10
sdcantrell56's Avatar
sdcantrell56 sdcantrell56 is offline
AKA: Sean
FRC #2415 (Wired Cats)
sdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond repute
Wow, I thought we were the only ones. We have been having the same issues with the BAG motor on our intake. Just changes rpm at will and it seems like moving the wires going into the motor have an effect on it as well.
Mentor 2415
Unread 27-02-2013, 08:15
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
We also have had some quirky bag motors. I'm not too sure on the specifics, but some of the issues seemed to be due in part to unsupported motor leads being pulled away from the case. We added a simple relief loop to the wiring and that seems to have done the trick.
Otherwise, BAG's are pretty awesome.
Unread 27-02-2013, 09:07
dman9385 dman9385 is offline
AKA: Dane Meyers
FRC #3098 (The Captains)
dman9385 will become famous soon enough
Send a message via AIM to dman9385 Send a message via Yahoo to dman9385
We've been experience the following
- They run with a variance of RPM when they do run.
- Sometimes after running once they don't turn back on. We go and spin the wheel lightly and it kicks on. (probably the brushes hanging up)
- We've had this issue with about 6 of them.
Obviously the risk of this happening is high and we don't want it happening during our matches so we have switched them out to the RS550.
Glad we weren't the only ones having issues.
2001 - 2003 - Driver/Student - Team 67
2004 - Drive Coach / Mentor - Team 406
2005 - Mentor - Team 1504
2006 - 2007 - Drive Coach - Team 1256
2008 - 2009 - Mentor - Team 1165
2010 - Present - Mentor/Scouting - Team 3098
Unread 27-02-2013, 09:13
Paul Copioli's Avatar Unsung FIRST Hero Woodie Flowers Award
Paul Copioli Paul Copioli is offline
President, VEX Robotics, Inc.
FRC #3310 (Black Hawk Robotics)
Rookie Year: 2000
Paul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond repute
All,
This has been brought to our attention, but we have taken apart several motors here in our inventory and have not found any of the problems you are describing. The best way we can help solve this issue is for you to work with our customer service department to send us your bad motors so we can investigate. We will send you out replacement motors immediately as long as you agree to send back your bad motors within one week.
Moving the wires to change RPMs, based on the construction method of this motor is highly unlikely to me so there must be something else. Please know that the construction method of the BAG motor internals is exactly the same as the CIM motor with smaller parts. The leads are mechanically isolated from the electrical connection to the brushes.
The most likely scenario is that the brushes are hanging up on the commutators, but we can only solve it if we get some motors back. We have plenty in stock and can ship you replacements same day.
EDIT: UPDATE - We are pulling all of the BAG motors from inventory and 100% inspecting for the lost commutator issue. I will send updates as we figure out the % of motors with this issue.
Paul
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
Unread 27-02-2013, 09:25
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
Paul
I believe this is the issue. In both cases that I can recall with our BAG motors, the motor was able to spin again once we rotated the shaft a small amount by hand.
I will find our bad BAGs and send them back. Thanks!
Unread 27-02-2013, 09:47
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
We had similar issues with 2 motors.
We took one apart and didn't see anything obvious, but it was late so we put a Mini CIM in its place (they're super easy to mount to the Versaplanetaries) and were happier with performance anyway.
Kettering Motorsports
Unread 27-02-2013, 11:51
Rookie Year: 2000
So here is an update: We have a few of the bad motors back from customers and they display the same symptom. I will try to explain briefly.
There are 7 commutators on the BAG motor and two brushes. For those not familiar with how a DC motor works, the commutators are the things that spin with the rotor (shaft) and contact the brushes to generate the magnetic field.
In the bad BAG motors, there is an open connection between the two wires that make up the winding. This results in one set of 3 commutators disconnected from a set of 4 commutators. When one brush is contacting only within the set of 3 and the other brush is contacting only within the set of 4 the motor will receive no current and not spin. This symptom will only show if the motor stops at a spot described above.
We are inspecting all of our BAG motors in inventory to find any motors with this condition. We have inspected about 500 so far and have not found any bad motors.
What we don't know is if this is a condition caused by use or a problem right out of the box. Our theory is that the problem is right out of the box so our inspections should eliminate this issue.
You can inspect your own motors by using a ohm meter on the two leads and spinning the motor slowly. If the resistance goes into the k Ohm or M Ohm range, then you have the problem.
We will replace all motors with this condition if you contact our customer support at support@vexrobotics.com.
  #15   Spotlight this post!
Unread 26-02-2013, 22:59
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is offline
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Team Role: Coach
AllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond repute
Send a message via AIM to AllenGregoryIV
We still haven't had issues with either our practice shooter or our real shooter but 2587 did have an issue at the end of week 6. So I'm not sure what the difference is. We also use ours to collect so we stall it pretty regularly when testing things and they have all been fine so far.
Team 647 | Cyber Wolf Corps | Alumni | 2003-2006 | Shoemaker HS
Team 2587 | DiscoBots | Mentor | 2008-2011 | Rice University / Houston Food Bank
Team 3847 | Spectrum | Coach | 2012-20... | St Agnes Academy
LRI | Alamo Regional | 2014-20...
"Competition has been shown to be useful up to a certain point and no further, but cooperation, which is the thing we must strive for today, begins where competition leaves off." - Franklin D. Roosevelt
