Go to Post (We're going to get a team going up here, I have faith. And nerds.) - ScoutingNerd175 [more]
Unread 27-02-2013, 20:13
Reggie335 Reggie335 is offline
AKA: Reginald
FRC #4297 (WeNoRobots)
Team Role: Leadership
Rookie Year: 2011
Reggie335 is an unknown quantity at this point
Robot Upgrade
Since Bag And Tag We Have been Working on Our Practice Robot And We have Dramatically Change Alot Of Stuff On the Practice Bot. So is it ok to Take Apart everything we have on our practice Bot and Transfer It to our Main Robot.
Unread 27-02-2013, 20:16
Grim Tuesday's Avatar
Grim Tuesday Grim Tuesday is offline
AKA: Simon Bohn
FRC #0639 (Code Red)
Rookie Year: 2010
Grim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond repute
Re: Robot Upgrade
You are allowed to bring in 30 lbs of fabricated items. For example, if you built a new shooter and brought it into the event, the entire thing would count towards the limit. However, if you disassembled the shooter into its component pieces (let's say a CIM motor and two unmodified Banebots wheels) those parts would not be counted as fabricated, though obviously, actual fabricated items would be. Inspectors will want to weigh your withholding allowance when you check in on Thursday. Good luck tomorrow!
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Robot Upgrade
Is the total weight of ALL fabricated items under 30 lbs? If so, then you should be OK. If it is NOT under 30 lbs, then take off any COTS items and reweigh the fabricated items. Repeat until you have no more COTS items that can be removed or you are under 30 lbs, whichever comes first. (If running out of COTS items comes first, bring raw material in place of some of the fabricated items and re-fabricate them at the event.)
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 27-02-2013, 20:18
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Robot Upgrade
That depends on what "everything" is. Anything that is COTS and is returned to the same state it was in when you bought it can be brought to your regional and put on the robot. Everything else (anything that you have modified - cut, drilled, filed, etc) counts in your 30 lbs of allowed fabricated items, per R21. If you go over 30 lbs, you'll have a problem!
Note, you can't open your bag until you get to your regional, so you can't transfer anything over until then!
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Robot Upgrade
As long as you stay under the thirty pound withholding limit yes.
We will be installing a shooter and new tilt mechanism on our robot. The total weight of both is around 20lbs.
The other thing to consider is how much time those changes will take on Thursday. Can you get the changes done in time to get inspected or even get a little practice? In can be a fine line.
Unread 27-02-2013, 20:55
AKA: Reginald
Rookie Year: 2011
Re: Robot Upgrade
We Have Added A Pneumatic System And Our Shooter Weight is 22 pounds And Everything Else Is T-Slotted Extrusion So Basically if , we Take Our Pneumatic System Apart And Bring Uncut T-Slotted Extrusion. We Will Be Okay Right?
Note: Our Competitions Is March 21-23 But Thanks And Good Luck To The Teams That Play Tomorrow
Unread 27-02-2013, 21:29
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
Re: Robot Upgrade
You should be ok, but slavishly look at the rules. We had a problem with the withholding allowance last year because we didn't know that bumpers counted. This year the rules are different, but you will just need to stay on top of them. As always, read the manual, it's your friend.
Sidenote:
Please check your Caps settings. Reading A Sentence That Looks Like This Is Very Annoying And Does Not Make You Look Professional.
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Unread 27-02-2013, 22:40
AKA: Reginald
Rookie Year: 2011
Re: Robot Upgrade
Thanks for the help
