2583-The Robowarriors presents Valkyrie
http://youtu.be/9v8soGWxTMI
Valkyrie's Specs Drivetrain: 8-wheel (4’’ 1.5’’ Wide Colsons) Toughbox Minis. Belt driven Theoretical speed-10 fps Shooter: 90 degree arc, direct driven 6in Hi-Grip wheel from a CIM 150 degrees of adjustable angle through PG-71 motor on leadscrew Piston fed shooter Frisbee Lift: 3 “Pizza Boxes” each with 20 grippy rollers on the sides to carry Frisbee up Completely gear driven, over 100 gears total, 20:1 with RS550 Motors Pick-up: Vacuum Suction Cup feeds into pizza boxes, one piston for compressing suction cup, one piston for almost instantaneous rotation Climber:10pt pneumatic powered hooks, soon to come 30 pt climber Completely 1/16’’ and 1/8’’ sheet metal Weight:110lbs Last edited by ferrari77 : 27-02-2013 at 22:16. |
