Go to Post It kicked off today, and we already have 10 pages of posts!?!?! - ShotgunNinja [more]
Unread 27-02-2013, 22:49
theface3352's Avatar
theface3352 theface3352 is offline
AKA: Luke
FRC #3352 (Flaming Monkeys)
Rookie Year: 2010
theface3352 is an unknown quantity at this point
Camera Example not working
Hi,
I'm trying to get my teams camera code running and basically I want to use the example code provided for us in Labview to get the distance to the target. The problem is though the example doesn't work when I run the Crio version on the robot. When I run it, it looks like the code is getting stuck at the update camera block but this code has never been modified and I've tried it on multiple computers so I'm really confused as to why it's not working. Also I know the camera is working because I can get it to stream to the driver station and the example will work when you run it with the pc version. And the ip address is also correct.
Thanks for the help in advance!
Unread 28-02-2013, 08:15
Re: Camera Example not working
Does the IP address match? What VI are you running, and what results do you get?
Greg McKaskle
Unread 28-02-2013, 17:21
AKA: Luke
Rookie Year: 2010
I'm running the vision processing vi and the ip is 10.33.52.6
Unread 28-02-2013, 22:52
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
10.te.am.6 is the suggested address for your programming computer. The cRIO program expects the camera to be at 10.te.am.11, which is where the "Setup Axis Camera" utility puts it.
