Go to Post Remember FIRST is "For Inspiration" of all students. It is a little tough to inspire students you won't allow in. - pafwl [more]
Unread 01-03-2013, 21:53
Ian Curtis Ian Curtis is offline
Best Available Data
FRC #1778 (Chill Out!)
Ian Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond repute
Which Match Score Gets Tweeted?
In light of the late breaking decision to recount match results by hand, does anyone know which score @FRCFMS is tweeting? Looking through the data I see a couple of negative numbers which add up to the final match result. Does the field only tweet the initial match result (and the goals are erroneously reporting negative numbers)? Or is the human scored match result posted to twitter (and the only way the field staff can edit the score is by changing the teleop score)?
Or am I totally off-base with both of these? Thanks!
CHILL OUT! | Aero Stability & Control Engineer
Adam Savage's Obsessions (TED Talk) (Part 2)
It is much easier to call someone else a genius than admit to yourself that you are lazy. - Dave Gingery
