Go to Post Welcome to ChiefDelphi.com. Get ready for the craziness. - Andy Baker [more]
Unread 02-03-2013, 05:36
rai337 rai337 is offline
FRC #1574 (Miscar1574)
Rookie Year: 2012
rai337 is an unknown quantity at this point
Servo isn't working..!
we're using a servo, and we connected him like a normal pwm with a jumper ofc, and we use him in the program and it doesn't working.. we're sure that we use it properly, and we also tried the example.. we know that the servo and the wire is working, can someone help, we are stuck...
Unread 02-03-2013, 05:50
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
Re: Servo isn't working..!
Which example are you following?
here's a tutorial on the subject. try following the steps there and see if it helps...
http://frcmastery.com/wp-content/upl...ry_Step_3.html
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 02-03-2013, 09:15
Rookie Year: 2012
it's exacly what we did actually.. we realy have no idea what's the problem..
Unread 02-03-2013, 09:33
Leav's Avatar
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
OK so troubleshooting 101: isolate the problem.
Do you have an oscilloscope? (I seem to remember that your lab is well equipped). If so, you should try measuring the output of the signal pin (don't forget to connect the ground pin to ground!)
are you getting signal?
if you see a square wave signal, that's a good sign already. measure the frequency, it should be between 30-50 Hz. (the signal should have a period of ~20ms to ~33ms).
if you see all that, something is wrong with the servo.
if you don't see any signal -> probably software problem or wrong wiring (Digital side car working?)
if you see a wrong signal
(bad frequency or shape) -> probably software problem
-Paraphrasing JFK
Unread 02-03-2013, 11:18
Rookie Year: 2012
We just solved the problem actually, from some reason the sidecar didn't work with the servo, so we're fine now. thanks anyway!
