Go to Post Belts are a fine way of transferring power in a robot. Like chains, gears, drive shafts, viscous couplings or any other means of transmission they require some care and attention on you're part. But no one said this robot stuff was going to be a cake walk. - Andy A. [more]
Unread 03-03-2013, 16:18
arun4444 arun4444 is offline
FRC #3760
arun4444 has a little shameless behaviour in the past
Quick help for a gear changing pneumatics system.
So if I were to put on these ball shifters:
http://www.vexrobotics.com/ball-shifter.html
They use the two following cylinders to change gears
http://www.vexrobotics.com/vexpro/ge.../217-2778.html
What would be the minimal pneumatics circuit I would need?
I think that a compressor is not needed, would need some tubing a solenoid? and what else?
I would greatly appreciate if someone could draw out the simplest circuit required - I am totally new to pneumatics and was thinking what would be required to swap out our gearbox which this one - there is no other pneumatics on the robot.
