Go to Post Best. Team. Update. Ever. - Billfred [more]
Unread 04-03-2013, 17:40
sunny1118 sunny1118 is offline
FRC #0224 (The Tribe)
Team Role: Leadership
Rookie Year: 2011
sunny1118 is an unknown quantity at this point
Making a 2 axis controller turn the robot
We have our 3 axis controller do the tank drive, but we also want our 2 axis controller to also rotate. We plan to use on the x-axis left turn the robot counter clock wise and right to trun the robot clock wise. We want to know if it is possible and how? We program in java.
Unread 04-03-2013, 20:16
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Making a 2 axis controller turn the robot
You didn't say what kind of drivetrain you have.
If it's a skidsteer, what you are describing sounds like Arcade Drive. Look in RobotDrive.java in the WPILib.
If you have mecanum, and you want independent control of FWD/REV, strafe Left/Right, and rotate (turn) CW/CCW, then you need three inputs.
Unread 04-03-2013, 21:00
Rookie Year: 2011
We are using mecanum, we have one of our joystick for drive and the other is auxil. We want the auxil to just rotate the robot and are not sure which arcade drive to use
Unread 04-03-2013, 23:31
Ether's Avatar
Rookie Year: 1969
If you want independent control of mecanum FWD/REV, strafe Left/Right, and rotate (turn) CW/CCW, then you need three inputs.
Arcade drive is for skid steer and does not take 3 inputs.
A 2-axis joystick does not produce 3 outputs (unless you want to use the throttle for the 3rd output).
The mecanumDrive_Cartesian() method in the RobotDrive.java file in WPILib takes three inputs.
You need a DI (Driver Interface) that gives the driver three controls: one each for fwd/rev, strafe left/right, and rotate CW/CCW.
So your DI could be this:
Y axis of Joystick1 is FWD/REV
X axis of Joystick1 is Strafe Right/Left
X axis of Joystick2 is Rotate CW/CCW.
... and just feed those three outputs into the appropriate 3 inputs of the mecanumDrive_Cartesian() method.
Unread 05-03-2013, 14:25
AsianRookie AsianRookie is offline
AKA: Steven/Tim
FRC #0321 (Robolancers)
Rookie Year: 2007
AsianRookie is an unknown quantity at this point
Well for the 2 axis joystick, you would have a toggle the mode or hold a button to rotate.
